Simply plug your new Edimax EW-7612UAn USB adapter into your computer's USB port, and you can enjoy high-speed wireless network access in just a few seconds. This wireless USB adapter provides a quick and simple way to add or upgrade the wireless connectivity of your desktop, laptop, or notebook computer. You can enjoy transfer rates as high as 300Mbps* when your Edimax EW-7612UAn USB adapter is connected to wireless 802.11n-compatible devices.
Wireless 802.11n Standard (data rates up to 300Mbps*)
Edimax EW-7612UAn has an extended wireless coverage and a higher data transfer rate. It is equipped with the latest wireless technology, which enables it to eliminate wireless dead spots while extending its wireless coverage by 4 times. The EW-7612UAn USB adapter is compatible with IEEE802.11b/g/n wireless standards, and is capable of transferring data at up to 300Mbps when connected to 802.11n wireless devices. The wireless technology in the Edimax EW-7612UAn USB adapter also extends its wireless signal distance, and provides more reliable wireless connections than traditional IEEE802.11b/g wireless networks.
Features a Hardware WPS (Wi-Fi Protected Setup) Button
Wi-Fi Protected Setup (WPS) is a new technology designed to establish a secure wireless network in a fast and easy way. If the wireless device you wish to connect supports WPS, the Edimax EW-7612UAn USB adapter will be able to establish a secure, encrypted WPA data connection with it. All you need to do is press the button, and you are set to go. The Edimax EW-7612UAn USB adapter supports both hardware (button) and software (web page) WPS.
Features Multi-Language EZmax Setup Wizard*
Edimax EW-7612UAn includes an EZmax setup wizard--a setup application available in 16 languages, which will assist you in connecting your new EW-7612UAn USB adapter with wireless networks in no time.
Built-in 3dBi Antenna and Hardwire USB Cable for Improved Wireless Performance
EW-7612UAn not only has a built-in 3dBi high gain antenna, it is also bundled with a free hardwire USB cable for improved wireless performance. When using EW-7612UAn with the hardwire USB cable, it provides better wireless performance at no extra cost
Wireless 802.11n standard
Edimax EW-7612UAn has an extended wireless coverage and a higher data transfer rate. It is equipped with the wireless technology, which enables it to eliminate wireless dead spots while extending its wireless coverage by 4 times. The EW-7612UAn USB adapter is capable of transferring data at up to 300 Mbps when connected to 802.11n wireless devices. The wireless technology in the Edimax EW-7612UAn USB adapter also extends its wireless signal distance, and provides more reliable wireless connections. -
Features a hardware WPS (Wi-Fi Protected Setup) button
Wi-Fi Protected Setup (WPS) is a technology designed to establish a secure wireless network in a fast and easy way. If the wireless device you wish to connect supports WPS, the Edimax EW-7612UAn USB adapter will be able to establish a secure, encrypted WPA data connection with it. All you need to do is press the button, and you are set to go. The Edimax EW-7612UAn USB adapter supports both hardware (button) and software (web page) WPS. -
Features multi-language EZmax setup wizard
Edimax EW-7612UAn includes an EZmax setup wizard - a setup application available in 16 languages, which will assist you in connecting your EW-7612UAn USB adapter with wireless networks in no time. -
Built-in 3dBi antenna and hardwire USB cable for improved wireless performance
EW-7612UAn not only has a built-in 3dBi high gain antenna, it is also bundled with a free hardwire USB cable for improved wireless performance. When using EW-7612UAn with the hardwire USB cable, it provides better wireless performance at no extra cost.
- Edimax EW-7612UAn - network adapter
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- 1.5 cm x 1.5 cm x 15.5 cm
- Data Link Protocol
- 802.11b/g/n
- Data Transfer Rate
- 300 Mbps
- Frequency Band
- 2.4 GHz
- IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, USB 1.1, USB 2.0, IEEE 802.11n
- System Requirements
- Linux, Apple MacOS X 10.4 or later, Microsoft Windows 2000/XP/Vista/7
- Network adapter
- Form Factor
- External
- USB 2.0
- Connectivity Technology
- Wireless
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- 300 Mbps
- Frequency Band
- 2.4 GHz
- Status Indicators
- Link/activity
- Wi-Fi Multimedia (WMM) support, Wi-Fi Protected Setup (WPS)
Aerial
- Antenna
- External integrated
- Gain Level
- 3 dBi
- 1 x aerial
- Connections
- 1 x USB 2.0 - 4 pin USB Type A
- Cables Included
- 1 x USB cable (external)
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2
- FCC, RoHS, WEEE
- Software Included
- EZmax Setup Wizard
- OS Required
- 1.5 cm
- 1.5 cm
- 15.5 cm
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
