Edimax EW-7811UAC AC600 Wireless Dual-Band USB adapter with 5 dBi A
Quicklinx: 9M6HWS00 Mfr#: EW-7811UAC
Wired / Wireless: Wireless
Protocol: IEEE 802.11n, IEEE 802.11g, IEEE 802.11b, IEEE 802.11a + 1 more
Form Factor: External
Compatibility: PC, Mac
Type: Network adapter
  • IEEE 802.11n
£19.95 ex VAT
£23.94 inc VAT
The 802.11ac wireless standard is set to revolutionize Wi-Fi. Super-speed 802.11ac dual-band routers are already available but wireless devices are still stuck with 802.11n technology. Upgrade your wireless device to dual-band 802.11ac with the USB 2.0 connectivity for blistering Wi-Fi speeds on the interference free 5 GHz frequency band. The EW-7811UAC is with a high gain, high-performance, and dual band antenna. This antenna can greatly increase the effective wireless operation range of 802.11 ac/a/b/g/n wireless devices.
  • Wi-Fi standard
    The Edimax EW-7811UAC is the next generation of Wi-Fi adapter, compatible with the draft 802.11ac standard and delivering speeds of up to 433 Mbps at 5 GHz - almost three times as fast as 802.11n. Upgrade PC's and notebooks to super high speed 802.11ac Wi-Fi and enjoy streaming video and data.
  • Dual-band connectivity
    Enjoy better performance and greater flexibility for your Wi-Fi devices, using dual-band connectivity. The EW-7811UAC provides connectivity for the 2.4 GHz band at speeds of 150 Mbps or 5 GHz band at speeds of 433Mbps. You can surf the Internet and check your email on the 2.4 GHz band, or select the 5 GHz band for online gaming and video streaming.
  • 4 dBi/6 dBi high gain antenna
    The EW-7811UAC High Gain Antenna, 4 dBi (2.4 GHz) and 6 dBi (5 GHz), provides high performance and long distance connections for your wireless network.
  • USB cradle for enhanced wireless signal
    The EW-7811UAC comes with a 1.2 meters cradle for flexible placement. Adjust the antenna position for peak performance at no extra cost.
Edimax EW-7811UAC - network adapter - USB 2.0
Network adapter
External
Interface (Bus) Type
USB 2.0
2 cm x 0.7 cm x 19 cm
18 g
802.11a, 802.11b/g/n, Wi-Fi 5
Data Transfer Rate
433 Mbps
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.1x
Linux, Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8, Windows 8.1
Network adapter
External
USB 2.0
Wireless
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft)
Data Transfer Rate
433 Mbps
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Link/activity
WPS, 802.1x authentication
IEEE 802.1x
Aerial
Antenna
External integrated
Antenna Qty
1
Gain Level
6 dBi
USB cradle
1 x USB cable - 1.2 m
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
FCC
2 cm
0.7 cm
19 cm
18 g
0 - 95% (non-condensing)
Protocol: IEEE 802.11g
Protocol: IEEE 802.11b
Protocol: IEEE 802.11a
Protocol: IEEE 802.11ac (draft)
Compatibility: PC
Compatibility: Mac
Brand: Edimax
