Complies with draft IEEE 802.11ac standard and backward compatible with wireless 802.11a/b/g/n standards
Dual-band wireless connectivity for 2.4GHz or 5GHz
Max. Wi-Fi speeds of 150Mbps (2.4GHz) or 433Mbps (5GHz)
- Features a hardware WPS (Wi-Fi Protected Setup) button for easy wireless connections
- Features easy setup wizard
- Supports Windows XP/Vista/7/8/8.1, Linux and Mac OS X (10.4~10.9 ) drivers
- Dual-band 3dBi antenna provides flexible and high performance wireless connections
- USB cradle for flexible placement and better wireless signal
The latest 802.11ac wireless standard is set to revolutionize Wi-Fi. Super-speed 802.11ac dual-band routers are already available but wireless devices are still stuck with 802.11n technology. Upgrade your wireless device to dual-band 802.11ac with the USB 2.0 connectivity for blistering Wi-Fi speeds on the interference free 5Ghz frequency band. The EW-7811USC is with a high-performance and dual band antenna. This antenna can greatly increase the effective wireless operation range of 802.11 a/b/g/n/ac wireless devices.
11ac Super High-Speed Wi-Fi
The Edimax EW-7811USC is the 11ac super high-speed Wi-Fi adapter, compatible with the latest IEEE 802.11ac standard and delivering speeds of up to 433Mbps at 5GHz - almost three times as fast as 802.11n. Upgrade PC’s and notebooks to super high-speed 802.11ac Wi-Fi and enjoy streaming video and data.
Dual-Band Connectivity
Enjoy better performance and greater flexibility for your Wi-Fi devices, using dual-band connectivity. The EW-7811USC provides connectivity for the 2.4GHz band at speeds of 150Mbps or 5Ghz band at speeds of 433Mbps. You can surf the internet and check your email on the 2.4GHz band, or select the 5GHz band for online gaming and video streaming.
Detachable Antenna
The EW-7811USC designed with a detachable 3dBi dual-band antenna provides flexible and high performance connections for your wireless network.
USB Cradle for Enhanced Wireless Signal
The EW-7811USC comes with a 1.2 meter cradle for flexible placement. Adjust the antenna position for peak performance at no extra cost.
Download and Stream Anywhere
Use the EW-7811USC to download and stream media from YouTube, Netflix or other services without waiting for buffering, or stream media across your network from a NAS (network-attached storage) at lightning speeds. Streaming HD movies or downloading is faster and more reliable than ever with 802.11ac Wi-Fi.
The Edimax EW-7811USC is the 11ac super high-speed Wi-Fi adapter, compatible with IEEE 802.11ac standard and delivering speeds of up to 433Mbps at 5GHz - almost three times as fast as 802.11n. Upgrade PC's and notebooks to super high-speed 802.11ac Wi-Fi and enjoy streaming video and data. -
Dual-band connectivity
Enjoy better performance and greater flexibility for your Wi-Fi devices, using dual-band connectivity. The EW-7811USC provides connectivity for the 2.4GHz band at speeds of 150Mbps or 5Ghz band at speeds of 433Mbps. You can surf the internet and check your email on the 2.4GHz band, or select the 5GHz band for online gaming and video streaming. -
Detachable antenna
The EW-7811USC designed with a detachable 3dBi dual-band antenna provides flexible and high performance connections for your wireless network. -
USB cradle for enhanced wireless signal
The EW-7811USC comes with a 1.2 meter cradle for flexible placement. Adjust the antenna position for peak performance at no extra cost. -
Download and stream anywhere
- Edimax EW-7811USC - network adapter - USB 2.0
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- 1.6 cm x 5 cm x 1.2 cm
- 8 g
- Data Link Protocol
- Wi-Fi 5
- Data Transfer Rate
- 433 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, IEEE 802.11ac
- System Requirements
- Linux, Apple MacOS X 10.4 - 10.9, Microsoft Windows Vista / XP / 7 / 8 / 8.1
- Network adapter
- Form Factor
- External
- USB 2.0
- Connectivity Technology
- Wireless
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- 433 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- Link/activity
- Wi-Fi Protected Setup (WPS), 802.1x authentication
Aerial
- Antenna
- External detachable
- Antenna Qty
- 1
- Gain Level
- 3 dBi
- Included Accessories
- USB cradle
- Cables Included
- 1 x USB cable - 1.2 m
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2
- FCC
- OS Required
- 1.6 cm
- 5 cm
- 1.2 cm
- 8 g
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
