Smart Load Balancing
Three load balancing types allow administrators to manage the load balancing methods best suited to the LAN environment and to maximize bandwidth across different connections.
High availability with double bandwidth
For small-to-medium size business, Load Balancer is the ideal product. With Load Balancer, up to 253 users are connected to the Internet with Double Broadband Speed.
QoS (Quality of Service)
Load Balancer supports QoS for controlling traffic priority. With QoS, businesses can make the critical traffic or application at high priority and route first.
WAN port Health Check to against connection fail
Load Balancer offers automatic outbound traffic backup to against the failure of either broadband connection to protect your business.
Smart load balancing
Three load balancing types allow administrators to manage the load balancing methods best suited to the LAN environment and to maximize bandwidth across different connections. -
For small-to-medium size business, load balancing is the ideal product. With load balancer, up to 253 users are connected to the Internet with double broadband speed. -
Load balancing supports QoS for controlling traffic priority. With QoS, businesses can make the critical traffic or application at high priority and route first. -
WAN port health check to against connection fail
Load balancing offers automatic outbound traffic backup to against the failure of either broadband connection to protect your business.
- Edimax BR-6624 - router - DSL modem - desktop
- Router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL
- WAN Ports Qty
- 2
- Data Link Protocol
- Ethernet, Fast Ethernet
- TCP/IP, PPTP, ICMP/IP, IPSec, PPPoE, ARP
- Routing Protocol
- RIP-1, RIP-2, static IP routing
- Remote Management Protocol
- SNMP, HTTP
- VoIP Protocols
- H.323
- Firewall protection, DHCP support, NAT support, VPN support, NAPT support, auto-uplink (auto MDI/MDI-X), SPI, DoS attack prevention, QoS
- IEEE 802.3, IEEE 802.3u, UPnP
- Router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wired
- Routing Protocol
- SNMP, HTTP
- Authentication Method
- CHAP
- IEEE 802.3, IEEE 802.3u, UPnP, FCC
Communications
- 2 x DSL modem
- ADSL
IP Telephony
- VoIP Protocols
- H.323
- WAN: 2 x ADSL - RJ-45 , LAN: 4 x 10Base-T/100Base-TX - RJ-45
