EdgeRouter combines carrier-class reliability with enterprise-level features in a compact and affordable unit. The EdgeRouter PoE is the economical router capable of routing up to 1 million packets per second.
Powered by a proprietary and intuitive graphical interface, EdgeOS, EdgeRouter can easily be configured for routing, security, and management features required to efficiently run your network. For advanced network professionals, an integrated CLI is available for quick and direct access using familiar commands.
DHCP server
Set up multiple DHCP servers to assign IP ranges in different subnets on the different interfaces. Easily control dynamic and static IP addressing for your network devices. -
Monitoring tools
Conveniently track network activity and devices from tools such as ping, trace, discover, packet capture, and log monitor. -
User accounts
Manage access to the EdgeRouter using unique administrator and operator accounts. -
Firewall policies
Organize the rules you apply in the order you specify. Firewall groups apply the policies to groups filtered by IP address, network address, or port number. -
NAT rules
The EdgeRouter changes packet addressing based on your customized source and destination NAT rules. -
Each Gigabit port functions as an independent interface. You can also configure virtual local area network (VLAN) interfaces for network segmentation. -
Routing
Configure static routes and dynamic routing protocols to effectively manage the routes used by the EdgeRouter. With these capabilities and more, the EdgeRouter provides the centralized control you need to optimize the performance and reliability of your network. -
Intuitive user interface
The EdgeRouter provides a graphical user interface designed for convenient setup and control. Accessed via a network port and web browser, the user-friendly interface provides intuitive management with a virtual view of the ports, displaying physical connectivity, speed, and status.
- Ubiquiti EdgeRouter PoE - router - desktop, wall-mountable
- Router - 5-port switch (integrated)
- Enclosure Type
- Desktop, wall-mountable
- Data Link Protocol
- Data Transfer Rate
- 1 Gbps
- Performance
- Forwarding performance (64-byte packet size): 1000000 packets per second , Forwarding performance (large packets): 3 Gbps
- PPTP, L2TP, IPSec, PPPoE
- Routing Protocol
- OSPF, RIP, BGP, IGMP, GRE, OSPFv3, RIPng
- Remote Management Protocol
- SNMP, Telnet, HTTP, SSH, CLI
- Flow control, firewall protection, Layer 3 switching, NAT support, VLAN support, dynamic DNS server, VRRP support, ACL support, QoS, RADIUS support, DHCP server, static IP mode, reset button, LLDP support, DHCP relay, NetFlow, static routing, IGMP proxy
- IEEE 802.1Q, IEEE 802.3ad (LACP)
- 20 cm x 9 cm x 3 cm
- 360 g
- Enclosure Type
- Connectivity Technology
- Wired
- 1 Gbps
- Performance
- Routing Protocol
- IEEE 802.1Q, IEEE 802.3ad (LACP), IC, FCC
- Processor
- 1 x MIPS MIPS64 500 MHz
- RAM
- 512 MB DDR2 SDRAM
- Flash Memory
- 2 GB
- Status Indicators
- Port status, power, PoE, link/activity
- LAN: 5 x 10Base-T/100Base-TX/1000Base-T (PoE) - RJ-45 , Management: 1 x RJ-45
- Power Device
- External power adapter
- 60 Watt
- OS Provided
- Ubiquiti EdgeOS
- 20 cm
- 9 cm
- 3 cm
- 360 g
- -10 °C
- 45 °C
- 10 - 90% (non-condensing)
