Eaton G3 Metered Input ePDUs provide a best-in-class design featuring billing grade accuracy monitoring of input and branch circuits on a local LCD pixel display or over a network connection. The high accuracy meter will measure current, voltage, power and energy for load balancing, capacity planning, efficiency monitoring and energy usage reporting. Designed for IT and data center applications means high reliability and a robust design made for high operating temperatures found in containment or networking closets.
Efficient power distribution
The Eaton ePDU G3 Metered Input power distribution unit is designed for efficient power management in a rack-mountable form factor, ensuring reliable distribution of power to power distribution devices. -
Rack-mountable design
With its rack-mountable form factor, this power distribution unit seamlessly integrates into existing server and network racks, optimizing space and improving cable management for a streamlined setup.
- Eaton ePDU G3 Metered Input - power distribution unit
- Power distribution unit - rack-mountable
- Rack Size
- 0U
- Input Wiring
- 3-phase
- Input Connectors
- 1 x power IEC 60309 32A
- Output connectors
- 30 x power IEC 60320 C13 , 12 x power IEC 60320 C19
- Networking
- Ethernet 10/100, RS-232
- Black
- 5.2 cm x 6.5 cm x 182.9 cm
- Height (Rack Units)
- 0U
- Black
- Input Voltage Range
- AC 200 - 240 V
- Input Wiring
- 3-phase
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Circuit Protection
- Circuit breaker
- Remote Management Interface
- 1 x management (Ethernet) - RJ-45 , 1 x management (RS-232) - RJ-45 , 1 x cascading - RJ-45 , 1 x USB - 4 pin USB Type A
- Cables Included
- Power cable - integrated - 3 m
- LCD display, voltage monitoring, current meter, vertical orientation, firmware upgradable
- CB
- 0 °C
- 60 °C
- 5.2 cm
- 6.5 cm
- 182.9 cm
