Eaton ePDU Metered Input - IEC60309 32A 3P Output 6XC13:12XC19
Quicklinx: CBDNWS00 Mfr#: EMIB07
New ePDU G3 Metered Input models feature best in class technologies, including ±1% billing grade accuracy, an advanced LCD pixel display, a hot-swap meter and the ability to daisy chain four ePDUs to share the same network connection and IP address.
  • Efficient power distribution
    The Eaton ePDU Metered model is designed for efficient power distribution, ensuring your PC and other devices maintain optimal performance with a reliable power supply.
  • Rack-mountable design
    With its rack-mountable form factor, this power distribution unit integrates seamlessly into your existing server environment, saving space and simplifying the setup process.
Eaton ePDU Metered - power distribution unit
Power distribution unit - rack-mountable
Rack Size
0U
Input Wiring
3-phase
Input Voltage
AC 100-240 V
Input Connectors
1 x power IEC 60309
Output connectors
6 x power IEC 60320 C13 , 12 x power IEC 60320 C19
Ethernet
Height (Rack Units)
0U
Input Voltage
AC 100-240 V
Input Wiring
3-phase
Input Connectors
1 x power IEC 60309
Max Electric Current
32 A
Remote Management Interface
Ethernet
1 x management (Ethernet)
Temperature sensor, rugged, low-profile, LED display, current meter
