Dynamode Virtual 7.1 Surround Sound USB 2.0 Adapter
Quicklinx: 7TQXWS00 Mfr#: USB-SOUND7
A Sound investment for your Computer.
Do you have a Notebook, Netbook or Desktop PC and need to connect your existing Stereo Speakers or Headset and Microphone but do not have the common 3.5mm Phono Jacks available? Are you looking for the latest virtual 7.1 surround sound for your Gaming or Multimedia experience? The new USB-SOUND7 from Dynamode is the ideal solution.
Small and compact, the Plug n' Play USB adapter simply plugs into any available USB Port on the Computer and allows immediate connection of Speakers, Headphones and/or Microphone into the standard 3.5mm Phono jacks located at the rear of the adapter. What's more it used the acclaimed C-Media chipset for outstanding realism in the world of surround sound by using the Xear 3-Dsimulation software.
Integral Volume and Microphone mute status, the new USB-SOUND7 is the ideal surround sound solution for Windows® and MAC® OS X systems.
  • Replaces the need for a traditional Sound Card
  • Virtual 7.1 Surround Sound experience
  • Advanced C-Media 108 or equiv. Chipset
  • Plug n' Play USB interface - installs in seconds
  • 1x 3.5mm audio Jack; 1x 3.5mm microphone Jack
  • Built-in digital Class B amplifier
  • Compact and stylish design - ideal for Notebooks
  • Ideal for Games, DVD entertainment and businesses
  • Compatible with Microsoft® Windows 98/ME/2000/XP,
  • Vista®, Windows7™ and MAC OS® 8.6+
  • Integral Volume, Mute and LED functionality
  • Approx. weight 51 grams
Dynamode USB-SOUND7 - sound card
Sound card
Enclosure Type
External
Interface Type
USB
Sound Output Mode
Stereo
Hardware Controls And Indicators
Volume control, mute button, status indicator
Sound card
External
Interface Type
USB
Audio Output
Sound Output Mode
Stereo
USB bus-powered
1 x audio line-out - mini-phone stereo 3.5 mm , 1 x microphone - mini-phone 3.5 mm , 1 x USB - 4 pin USB Type A
Plug and Play
Software
C-Media Xear 3D
