Dynamode 2-Port SuperSpeed USB3.0 PCIe Card
Quicklinx: 72BVWS00 Mfr#: USB-2PCI-3.0
Welcome to the next generation of Super Speed Data Transfer.
Looking to move up and take advantage of up to ten times the speed of your existing USB2.0 devices? Want to add SuperSpeed™ peripherals but don't have the necessary USB3.0 ports on your Computer? Introducing the new Dynamode USB-2PCI-3.0 which is the latest in highperformance, fully certified SuperSpeed USB3.0 PCI Express Interface Cards allowing compatible USB3.0 devices to communicate at up to 5Gbps, up to ten times the speed of existing USB2.0 devices!
Using the latest NEC™ D70200 USB3.0 chipset, the Dynamode USB-2PCI-3.0 incorporates two SuperSpeed™ USB3.0 Ports which of course are fully backward compatible with existing USB2.0 Devices and any USB2.0 cables you may have. Fully Plug n' Play, the USB-2PCI-3.0 is fully Windows™ Vista and Windows™7 compatible. Now there's no easier and cost-effective way in moving up to the fast lane of SuperSpeed™ USB3.0 connectivity!
Advanced features
  • SuperSpeed™ USB3.0 ~ up to 5Gbps speeds
  • Dual SuperSpeed™ USB3.0 Ports on riser bracket
  • Fully backward compatible with USB2.0 and Cables
  • Advanced NEC™ D70200 SuperSpeed™ chipset
  • Plug n' Play PCI Gen2 Express Ver 2.0 specification
  • Intel™ xHCI rev 0.96 compliant
  • Supports LowSpeed, FullSpeed, HiSpeed & SuperSpeed™
  • Accepts USB3.0 and USB2.0 Data Cables
  • Integral `Molex' Power Boost adapter for increased length
  • Ideal for Microsoft™ Windows 2000/XP/Vista™/ 7™
  • Bundled USB3.0 PCIe card and CD ROM
Resources
The following resources are available for the Dynamode 2-Port SuperSpeed USB3.0 PCIe Card
