Welcome to the next generation of Super Speed Data Transfer.
Are you getting frustrated by long Backup or Restore times of your existing USB2.0 based Hard Disk system? Do you require faster data transfer for watching your stored HD Movies or digital music? Introducing the new Dynamode USB-HD-2.5S-3.0 which is one of the first external Disk Enclosures to feature the new SuperSpeed™ USB3.0 interface. Up to x10 the data throughput of existing USB2.0, SuperSpeed™ USB3.0 allows up to 5Gbps transfer speeds to your existing USB3.0 interface but at the same time being totally USB2.0 compatible so to protect your existing hardware.
Supporting almost all 2.5" SATA interface Hard Disks with a storage capacity of around 2TB, the new USB-HD-2.5S-3.0 features advanced features to get the most out of this exciting new technology including Hardware Encryption and built-in 32-bit RISC CPU. Stylish in design with pocket-sized form factor, Windows™ and MAC™ compatible and bundled with a SuperSpeed™ USB3.0 Data cable and Carry Pouch.
Advanced features
- SuperSpeed™ USB3.0 ~ up to 5Gbps speeds
- Backward compatible to HighSpeed USB2.0
- 2.5" SATA I/II (1.5Gbps and 3Gbps) interface
- Supports up to 2TB (Terabytes) Hard Disk Drive
- Bus-powered, no need for external Power Supply
- On-the-fly Hardware Encryption (AES type)
- On-board 32-Bit RISC MPU to reduce data overhead
- Stylish with small form factor - just add a Hard Disk
- Ideal for Windows™ 98/ME/2000/XP/VISTA, Windows7™
- Ideal for MAC™ OS 8.6 or higher
- Bundled SuperSpeed™ Cable, Fixing Kit, CD, Carry Pouch
