Tired of complicated labelers? Simplify labeling with the DYMO XTL 300. A life-like on screen print preview and built-in label applications help save time on the job. Prints labels from ¼" (6 mm) up to 1" (24 mm), including heat-shrink tubes, barcode and pre-sized labels.
- DYMO XTL 300 - Kit - labelmaker - B/W - thermal transfer
- Printer Type
- Labelmaker - thermal transfer - B/W
- Form Factor
- Portable
- Max Media Size
- Roll (2.4 cm)
- Max Media Size (Custom)
- 24 mm
- Print Speed
- Up to 23 mm/sec - max speed
- Max Resolution (B&W)
- 300 dpi
- Interface
- USB
- Flash Memory Installed (Max)
- 41 MB
- Barcodes
- Code 39, QR code, UPC-A, Codabar, Code 128, PDF417, EAN-8, EAN-13
- Media Type
- Vinyl labels
- 11 line printing
- Keyboard
- QWERTY
- Battery
- Lithium polymer
- System Requirements
- Microsoft Windows 7 / 8 / 8.1 / 10
- 3-year warranty
- Printer Type
- Labelmaker - thermal transfer - monochrome
Printer
- Print Speed
- Built-in Devices
- Preview screen, character keyboard
- Connectivity Technology
- Wired
- Interface
- USB
- 300 dpi
- 11 line printing
- Keyboard
- QWERTY
- Barcodes
Flash Memory
- Flash Memory
- 41 MB
Media Handling
- Media Type
- Vinyl labels
- Max Media Size
- Roll (2.4 cm)
- 24 mm
- Media Sizes
- Roll (2.4 cm)
- Media Feeders
- 1 x manual - 1 cassette - Roll (2.4 cm)
- Connections
- 1 x USB
- Included Accessories
- Carrying case
- Cables Included
- 1 x USB cable
- Media Included
- 1 roll of 150 21 x 39 mm black on white laminating labels, 1 24 mm x 7 m black on white vinyl tape cassette
- Power Device
- Power adapter - external
- Lithium polymer
- OS Required
- Limited warranty - 3 years
