DYMO XTL 500 Kit Labelmaker Monochrome Thermal Transfer
Quicklinx: CG4PWS00 Mfr#: 1873306
End frustration and simplify labeling with the DYMO XTL 500. A life-like on screen print preview shows exactly how labels will look, while a color touch screen and built-in label applications make getting started easy. Prints labels from ¼" up to 2" wide in a full range of UL-rated materials and colors.
DYMO XTL 500 - Kit - labelmaker - B/W - thermal transfer
Printer Type
Labelmaker - thermal transfer - B/W
Portable
United Kingdom, Ireland
Max Media Size
Roll (5.4 cm)
Max Media Size (Custom)
54 mm
Print Speed
Up to 28 mm/sec - max speed
Max Resolution (B&W)
300 dpi
Cutter
USB
Flash Memory Installed (Max)
41 MB
Barcodes
Code 39, QR code, UPC-A, Codabar, Code 128, PDF417, EAN-8, EAN-13
Media Type
Vinyl labels
24 line printing
Keyboard
QWERTY
Lithium polymer
Microsoft Windows 7 / 8 / 8.1 / 10
3-year warranty
Printer Type
Labelmaker - thermal transfer - monochrome
Printer
Print Speed
Built-in Devices
Character keyboard, touch screen
Wired
USB
300 dpi
24 line printing
Auto Cutter
Keyboard
QWERTY
Barcodes
Flash Memory
Flash Memory
41 MB
Media Handling
Media Type
Vinyl labels
Max Media Size
Roll (5.4 cm)
54 mm
Media Sizes
Roll (5.4 cm)
Media Feeders
1 x manual - 1 cassette - Roll (5.4 cm)
1 x USB
Carrying case
1 x USB cable
Media Included
1 roll of 150 38 x 39 mm black on white laminated labels, 1 54 mm x 7 m black on white vinyl tape cassette
Power adapter - external
Lithium polymer
Limited warranty - 3 years
