Label and organize anywhere in your home. Small, Sleek and super portable, the hand-held DYMO LetraTag LT00H makes it easy to organize each and every room in your home.
- DYMO LetraTag LT-100H - labelmaker - B/W - direct thermal
- Printer Type
- Labelmaker - direct thermal - B/W
- Form Factor
- Portable
- 280 g
- Max Media Size
- Roll (1.2 cm)
- Max Media Size (Custom)
- 12 mm
- Max Resolution (B&W)
- 160 dpi
- Cutter
- Media Type
- Iron-on tape, paper tape, metallic tape, plastic tape
- Compatible Tapes
- LetraTag tape
- Character Sizes
- 5 sizes
- Styles & Effects
- Bold, normal, vertical, outline, shadow, italic, underline, boxes around text
- 1 line printing, 2 line printing, realtime clock
- Display Resolution
- 1 line x 13 characters / 50 x 25
- Keyboard
- ABCD / 45 keys
- Battery
- Required 4 x AA type Included Qty 0
- 9.5 cm x 21.5 cm x 6.5 cm
- Printer Type
- Labelmaker - direct thermal - monochrome
Printer
- Built-in Devices
- Preview screen, character keyboard, cutter
- 160 dpi
- Character Sizes
- 5 sizes
- Styles & Effects
- Cutter
- Keyboard
- ABCD / 45 keys
Media Handling
- Media Type
- Compatible Tapes
- LetraTag tape
- Max Media Size
- Roll (1.2 cm)
- 12 mm
- Media Sizes
- Roll (1.2 cm)
- Media Feeders
- 1 x manual - 1 cassette - Roll (1.2 cm)
- Consumables Included
- 1 x tape cassette
- AA type
- Required Qty
- 4
- Included
- 0
- 9.5 cm
- 21.5 cm
- 6.5 cm
- 280 g
DYMO Plastic Tape 12MMX4M | In Stock | £5.13 |
DYMO LetraTag Tape 12mm Plastic Transparent | In Stock | £5.04 |
DYMO LetraTAG Plastic Tape 1 Roll - Black on Red | In Stock | £6.57 |
