Organize at home with big-business labeling power. The DYMO LetraTag LT 100T is compact and easy to use - but offers many advanced labeling options.
- DYMO LetraTag LT-100T - labelmaker - B/W - direct thermal
- Printer Type
- Labelmaker - direct thermal - B/W
- Localisation
- Netherlands, United Kingdom
- Max Media Size
- Roll (1.2 cm)
- Min Media Size (Custom)
- 12 mm
- Max Media Size (Custom)
- 12 mm
- Cutter
- Media Type
- Iron-on tape, paper tape, metallic tape, plastic tape
- Compatible Tapes
- LetraTag tape
- Character Sizes
- 5 sizes
- Styles & Effects
- Bold, normal, vertical, outline, shadow, italic, underline, boxes around text
- 1 line printing, 2 line printing, realtime clock
- Display Resolution
- 1 line x 13 characters
- Keyboard
- QWERTY
- Battery
- Required 4 x AA type
- Printer Type
- Labelmaker - direct thermal - monochrome
- Localisation
Printer
- Built-in Devices
- Preview screen, character keyboard, cutter
- Character Sizes
- 5 sizes
- Styles & Effects
- Cutter
- Keyboard
- QWERTY
Media Handling
- Media Type
- Compatible Tapes
- LetraTag tape
- Max Media Size
- Roll (1.2 cm)
- 12 mm
- 12 mm
- Media Sizes
- Roll (1.2 cm)
- Media Feeders
- 1 x manual - 1 cassette - Roll (1.2 cm)
- FCC Class B certified, EN 60950, EN 61000-3-2, IEC950, UL 1950, EN 61000-3-3, EN55024, EN 61000-4-4, EN 61000-4-2, EN50204, EN 61000-4-3, EN 61000-4-6, EMC, EN 61000-4-5, EN 61000-4-11, RoHS, EN 61000-4-8, EN 61000-6-3
- AA type
- Required Qty
- 4
DYMO Plastic Tape 12MMX4M | In Stock | £5.07 |
DYMO LetraTag Tape 12mm Plastic Transparent | In Stock | £5.07 |
DYMO LetraTAG Plastic Tape 1 Roll - Black on Red | In Stock | £6.27 |
