Easy to use Label maker with fast-formatting keys. Start organizing your office and telling your story - one label at a time.
- DYMO LabelMANAGER 160 - labelmaker - B/W
- Printer Type
- Labelmaker - B/W
- 350 g
- Localisation
- Hong Kong, United Kingdom
- Max Media Size
- Roll (1.2 cm)
- Max Media Size (Custom)
- 12 mm
- Media Type
- Labels
- Compatible Tapes
- D1 tape
- Styles & Effects
- Vertical
- Keyboard
- QWERTY
- Battery
- Required 6 x AAA type Included Qty 0
- Enclosure Colour
- Black
- 3-year warranty with product registration
- 11.8 cm x 4.9 cm x 20.3 cm
- Printer Type
- Labelmaker - monochrome
- Enclosure Colour
- Black
- Localisation
Printer
- Built-in Devices
- Preview screen, character keyboard
- Styles & Effects
- Vertical
- Keyboard
- QWERTY
Media Handling
- Media Type
- Labels
- Compatible Tapes
- D1 tape
- Max Media Size
- Roll (1.2 cm)
- 12 mm
- Media Sizes
- Roll (0.6 cm), Roll (1.2 cm), Roll (0.9 cm)
- Media Feeders
- 1 x manual - 1 roll - Roll (1.3 cm)
- Media Included
- 1 12 mm x 3 m black on white D1 label tape cassette
- AAA type
- Required Qty
- 6
- Included
- 0
- Limited warranty - 3 years
- 11.8 cm
- 4.9 cm
- 20.3 cm
- 350 g
Ink (2)
DYMO D1 12mm Tape - Black on Yellow | In Stock | £14.41 |
DYMO D1 9mm Tape - Black on Yellow | In Stock | £13.23 |
Other bundles (1)
DYMO D1 12mm Tape Black/White | In Stock | £14.41 |
