Drobo DR-B810N-5A31 8bay B810n NAS Storage Array
Quicklinx: BQGXWS00 Mfr#: DR-B810N-5A31
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
The B810n is a fusion of large and fast. It can present itself as a single large pool of storage. If you add two SSDs, it accelerates access to commonly used "hot" data. Ideal for a network of many users, the Drobo B810n can store and share files. Use it as your primary storage for important files and documents OR as a place to backup files, projects, or even connect computers on the network.
  • SSD accelerated performance
    The B810n was designed to provide all users uniform performance. Add two SSDs and you can accelerate performance for all simultaneous users. The technology uses two techniques to accelerate access to your data. Data Tiering as transactional data (small pieces of data) is read or written it is placed in SSD storage. Subsequent reads or writes to these blocks are almost instantaneous as there is no delay induced by a hard drive's magnetic head having to move into position. Active, or "hot" data, is stored in an SSD tier of storage. As it cools, i.e. access decreases, the B810n will move the data to the hard drive tier. Hot Data Cache - this is a technique to accelerate data reads. As data is read from hard drives, the B810n will prefetch nearby data that it predicts will be also be read. Your benefit is faster access and less waiting.
  • Dual Ethernet ports
    The B810n has dual Gigabit Ethernet ports. These can be bonded together to provide approximately twice the read/write performance you get via a single port. Or they can be used to provide a connection to two different subnets. Furthermore, they can be used in an "active/passive" mode so that if one port fails the other takes over.
  • Share files with OS X, Windows, or Linux Users
    Don't worry about compatibility - Drobo the B810n works with computers running OS X, Windows, or Linux operating systems. By default, the Drobo B810n uses the SMB file sharing protocol to talk to OS X or Windows. If you set up a share for Time Machine backup, it uses Apple's AFP protocol. Linux users pick which file sharing method to use on their system.
  • Offsite data replication built-in
    The B810n has a feature called "Drobo DR" (DR = disaster recovery). You can set up a pair of B810ns to automatically make an offsite copy of your data. This provides an easy to setup offsite backup of your important data. Even better, the remote B810n stores all user account information so that recovery is a breeze.
  • Protecting your critical data from power loss
    Drobo protects your data from loss in the event of a sudden power outage. This protects directory structures ensuring Drobo will remount on your computer. Drobo has a battery inside that powers RAM memory. When there is a power outage, data is stored on internal flash-based nonvolatile storage. Your data is safe until power returns. The battery recharges itself and lasts for the life of the product.
  • Add customized functionality with DroboApps
    DroboApps add functionality to your Drobo B810n. Whether it's cloud back up provided by either Crashplan or Elephant Drive or the video and music streaming offered through the Plex media server, these simple-to-install apps extend the capabilities of your Drobo B810n.
Drobo B810n - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
Max Supported Capacity
80 TB
0 (installed) / 8 (max)
30.91 cm x 35.81 cm x 13.87 cm
Storage Controller
SATA SATA 6Gb/s
10Mb LAN, 100Mb LAN, GigE
Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits), Microsoft Windows Server 2012 (32/64-bits), Apple MacOS X 10.8 or later, Windows 8.1 (32/64 bits), Windows 10 (32/64 bits)
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
80 TB
30.91 cm
35.81 cm
13.87 cm
Built-in Devices
Led panel
Storage Controller
SATA
Interface Type
SATA 6Gb/s
Network Services Compatibility
Microsoft CIFS, Server Message Block (SMB), Apple File Protocol (AFP)
Jumbo Frames support
Expansion Bays
8 (total) / 8 (free) x hot-swap - 2.5"
2 x Ethernet 1000Base-T - RJ-45
2 x network cable - 1.8 m
BeyondRAID technology, built-in cooling fan
UL, TUV, cUL, CISPR 22, CB, ICES-003 Class B, MIC, AS/NZS 3548, RoHS, WEEE, BSMI CNS 13438, FCC Part 15 A, ACA, REACH, VCCI V-3
Internal power supply
82 Watt
10 °C
35 °C
5 - 80%
Sound Emission
30.4 dB
