This module has 4 ISDN interfaces which can be connected to standard ISDN2e (BRI) lines providing up to 8 voice channels per module. This allows full integration of your existing ISDN lines into the IPPBX deployment. Incoming calls on ISDN or VoIP can be distributed to extensions exactly as you wish, and outgoing calls made over ISDN or your VoIP trunk according to your own preferences.
- DrayTek - ISDN terminal adapter - BRI
- Form Factor
- Internal
- Digital Signaling Protocol
- ISDN 2e
- ISDN Interface
- ISDN BRI
- Voice Communication Support
- VoIP
- Digital Ports Qty
- 4
- Designed For
- Vigor 3300V+; VigorIPPBX 3510
- Form Factor
- Internal
Modem
- Connectivity Technology
- Wired
- ISDN 2e
- ISDN Interface
- ISDN BRI
- VoIP
- Digital Ports Qty
- 4
- 4 x ISDN BRI
- Compatible Slots
- 1 x Expansion Slot
- Designed For
- Draytek Vigor 3300V+ , Draytek VigorIPPBX 3510
