DrayTek
VigorAP 920RPD 802.11ac Access Point with PoE Passthrough
DrayTek VigorAP 920RPD 802.11ac Access Point with PoE Passthrough
Quicklinx: F0DKWS00 Mfr#: VAP920RPD-K
  • IEEE 802.11n
Marketing description is not available.
  • MU-MIMO 802.11ac Wave 2
    VigorAP 920R Series provides concurrent dual-band, allows up to 128 clients on each band, 256 clients totally. It features advanced Wi-Fi technology, 802.11ac Wave 2 in the 5GHz band and 802.11n in the 2.4G band. The support of Multi-User MIMO (MU-MIMO) allows it to deliver high-performance wireless connection even in a crowded network.
  • IP67 rated dust & water resistant
    VigorAP 920R Series is IP67 certified water and dust-resistant, and its industrial-grade components make it able to withstand cold and heat. VigorAP 920R can be operated well between -40 °C and 70 °C, and therefore is suitable for extreme weather conditions.
  • PoE power input & energy efficient
    In response to the needs of energy saving, VigorAP 920R Series is IEEE802.3az compliant to reduce its energy consumption when data activity is low. VigorAP 920R Series can also be powered by Power over Ethernet to provide a flexible installation. Moreover, VigorAP 920RPD can be powered by PoE, and at the same time provides power to another PoE-PD, such as an IP camera.
  • A robust wireless bridge
    VigorAP 920R Series offers various operating modes, including access point and universal repeater. VigorAP 920RPD can also be a wireless bridge between two or more wired networks and help you extend the network to detached buildings without wires. Except for the two external antennas, VigorAP 920RPD also includes internal directional 5GHz antenna specialized in point-to-point deployment, therefore can deliver robust and fast connectivity over a long distance.
Draytek VigorAP 920RPD - radio access point - Wi-Fi 5
Radio access point
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Frequency Band
2.4 GHz, 5 GHz
Performance
Maximum data rate (2.4 GHz): 400 Mbps , Maximum data rate (5 GHz): 867 Mbps
Wireless clients per Wi-Fi radio: 128 , SSIDs per radio: 4
Power Over Ethernet (PoE) Supported
PoE
16 cm x 8 cm x 25.5 cm
Radio access point
16 cm
8 cm
25.5 cm
External
Wireless
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, CLI, TR-069
Frequency Band
2.4 GHz, 5 GHz
Performance
Load balancing, repeating mode, Syslog support, Wireless Distribution System (WDS) support, Access Point operational mode, firmware upgradable, Wi-Fi Multimedia (WMM) support, Wi-Fi Protected Setup (WPS), DHCP server, hidden SSID, temperature / humidity sensor, wireless bridge mode, reset button, 2T2R MIMO technology, DHCP relay, RSSI Threshold, Airtime Fairness, client isolation, dustproof, waterproof, MAC clone
Encryption Algorithm
TLS, PEAP, WPA, WPA2, WPA-PSK, WPA2-PSK, WEP
Authentication Method
RADIUS
IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac Wave 2
Aerial
Antenna
External detachable
Antenna Qty
2
Directivity
Directional
2 x 1000Base-T (PoE) - RJ-45 , 2 x aerial
IP67
PoE
-40 °C
70 °C
5 - 95% (non-condensing)
