Dicota Top Traveller BASE 15-17.3" Black
Quicklinx: FC3HWS00 Mfr#: D31671
Live smart with Top Traveller BASE! The handy toploader case protects your notebook perfectly thanks to the cushioned notebook compartment with metal wire frame. This lightweight notebook case guarantees flexible mobility - both professionally and privately.
Your 15-17.3" notebook is optimally protected with High-Density Foam (HDF) padding. The case also has space for your documents. You can store mobile accessories in the front pocket. So all your important things are handy at all times. The shoulder strap is removable and the length can be adjusted. Thanks to its padded neoprene carry handle, the case is comfortable to hold and can be instantly fixed to the trolley using the integrated strap - the smart case from the lightweight class!
  • Top-loading case with cushioned inner notebook compartment with High-Density Foam (HDF)
  • Further space for documents
  • Neoprene padded handle
  • Additional front compartment for mobile accessories
  • Trolley belt at the back panel
  • Removable shoulder strap (adjustable in length)
DICOTA Top Traveller BASE - notebook carrying case
Notebook carrying case
44 cm x 9.5 cm x 33 cm
798 g
Notebook Compatibility
17.3"
Notebook Supported Sizes
15" - 17.3" / 38.1 cm - 43.9 cm
Carrying Strap
Trolley strap, top carry handle, removable shoulder strap, adjustable shoulder strap
44 cm
9.5 cm
33 cm
798 g
17.3"
Notebook Compatibility Dimensions
42 cm x 29.5 cm x 4 cm
Additional Compartments
Documents, mobile accessories, front pocket
Carrying Strap
