Dicota Security Cable Wedge Lock, preset code, 3.2x4.5mm slot
Quicklinx: FS33WS00 Mfr#: D31566
A notebook can be stolen in an instant. Expensive hardware and important data are lost. This can involve a lot of work and great expense. Police, insurance, data recovery etc. Targeted prevention is the answer - with a quality lock from DICOTA. Easy, convenient and effective. The larger locking systems are designed for professional use. An integral solution is configured and produced individually for your company. Ideal for use in open-plan offices, public areas or during travel.
Without key and without compromising on security thanks to the 4-digit numeric code with 10,000 possible combinations. Notebooks as well as projectors, monitors and printers can be effectively secured with the DICOTA locking systems. Currently, device manufacturers use three different formats for the lock slots. The Security W-Lock Combination is suitable for all models with a 3.2 x 4.5mm slot. Thereby a rubber buffer prevents scratches on your equipment and at the same time ensures a seamless fit. Enjoy high flexibility in workplace design thanks to the swiveling closing head with a rotatable cylinder. The sheathed multi-strand steel cable is 2m long and has a diameter of 4.4mm. The functional Velcro strap allows the cable to be rolled up for compact storage and transportation. This lock is designed to be used in a larger locking program. Each user receives an individual lock that is secured by a predefined numeric code. At the same time, the IT manager has maximum control and can identify the code for each lock via the engraved number.
DICOTA Security W-Lock Masterkeyed - security cable lock
Security cable lock
Product Material
Steel, thermoplastic rubber
Length
2 m
230 g
Combination lock, touch fastener, 4 digit code, for 3.2 x 4.5mm slot, rubber buffer, swivelling closing head, rotatable cylinder
Security cable lock
Product Material
Length
2 m
230 g
Expanded Dimensions
Cable - 0.44 cm x 0.44 cm
