Dicota Eco Multi Plus BASE 14-15.6"
Quicklinx: G90SWS00 Mfr#: D30491-RPET
More than 50 In Stock
£24.44 ex VAT
£29.32 inc VAT
The compact Eco Multi Plus BASE Clamshell case with extra document storage offers ideal protection for your laptop thanks to its padded notebook compartment. The case fully protects devices and the elastic strap also secures them within their compartment. The Eco Multi Plus BASE guarantees extra stability and protection with its metal frame, as well as flexible mobility thanks to its lightweight design. You can store your documents in the dedicated front zipped compartment. Your smartphone or other smaller items like cables, pens or chargers can be stored in the convenient front pocket, so they are always to hand.
The case's handles make it comfortable to carry and it can be attached to a suitcase in seconds with its built-in strap. It can also be carried using its adjustable shoulder strap. The Eco Multi Plus BASE is therefore perfect for you if you are always on the go and want to support the recycling of PET bottles with an eco-friendly case.
DICOTA Eco Multi Plus BASE - notebook carrying case
Notebook carrying case
Product Material
Metal, 300D RPET polyester
41 cm x 9 cm x 29.5 cm
880 g
Notebook Compatibility
15.6"
Notebook Supported Sizes
14" - 15.6" / 35.6 cm - 39.6 cm
Metal frame, elastic fixation straps, padded notebook compartment
Carrying Strap
Top carry handle, removable/adjustable shoulder strap
30 years warranty
Product Material
41 cm
9 cm
29.5 cm
880 g
15.6"
Notebook Compatibility Dimensions
38.5 cm x 26.5 cm x 4 cm
Additional Compartments
Mobile phone, cable, documents, pens, mobile accessories, chargers, front zippered pocket
Carrying Strap
Closure Type
Zipper
REACH
Limited warranty: - 30 years
Brand: Dicota
