Dicota Privacy filter 2-Way for Monitor 22" Wide (16:10), side-mounted
Quicklinx: 9223WS00 Mfr#: D30125
Due to the increase in business mobility, notebooks have become ever more popular in the last few years. Especially in public areas, the data on notebook screens is hard to conceal from the view of passer-by's. But Dicota has the solution for you! Secret is a highly effective protective filter for your screen which prevents personal and confidential information from falling into the wrong hands.
Secret is directly attached to the screen and fastened with small flaps. The synthetic material consists of fine lamellas. Scratches and fingerprints are prevented by the protective filter. Due to the innovative Microlouver technology Secret offers aside from the anti-reflective function, glare protection which allows easy working even in sunshine. Thanks to the viewable angle of up to 30° for each side, the user has an unlimited view onto to the screen, while from the side a reflective surface is all that can be seen.
DICOTA display privacy filter - 22" wide
Display privacy filter - 2-way
Installation Type
Plug-in/adhesive
Display Screen Size Compatibility
22" wide
Product Material
PET
47.4 cm 29.7 cm
70 g
22" wide
Product Material
PET
47.4 cm 29.7 cm
70 g
Display Filter
Privacy Protection
2-way
Installation Type
Plug-in/adhesive
Aspect Ratio
16:10
Scratch Resistant
Material Thickness
0.38 mm
Anti-glare, anti-reflective, blue light cutting, touch capable
