devolo Mesh WiFi: All devolo units form a coherent network that not only amplifies your router WiFi, but also replaces it optimally – for seamless reception.
- High-performance Wi-Fi: Up to 100 end devices can be supplied across rooms at maximum speed, with the choice of 2.4 or 5 GHz Wi-Fi.
- Optimum mesh tri-band: The combination of Wi-Fi ac with Powerline technology enables the best distribution of Internet throughout the home – for a stable connection.
- Flexible: Additional Gigabit LAN ports and power outlets provide more connection options for your end devices.
- Compatible with all devolo Magic series adapters and can be expanded at any time. (devolo dLAN series adapters are not supported.)
- 3-year manufacturer's warranty.
Mesh Wi-Fi in its best form
Surf without gaps! Unlike conventional starter kits for home networking, the devolo Mesh WiFi set consists exclusively of WiFi units that replace your existing router WiFi with a pure mesh network. Up to 100 terminal devices can be supplied with WiFi at maximum gigabit speeds in a cohesive network. Eradicate wireless gaps and experience the best network coverage!
The fastest tri-band of its class
WiFi ac meets Powerline: Perfect Wi-Fi is transmitted to all end devices over two frequencies (2.4 and 5 GHz) with secure encryption. The devolo units distribute the Internet signal via power line throughout the home, ensuring a lightning-fast, stable network!
Adapts to your home!
The devolo Mesh WiFi network can be flexibly expanded at any time – you can easily connect additional devolo units to the existing network at the touch of a button. In the devolo mesh network, all settings for data security and performance optimisation are automatically synchronised.
A tip for even better mesh performance
For unimpaired performance, please switch off the router Wi-Fi. The devolo units then form a pure devolo mesh network. By using this trick, you enable the full range of functions of the perfectly co-ordinated devolo units and provide a performance boost – particularly in the case of older routers. Now your end devices will no longer be throttled by obsolete router Wi-Fi.
A real team player
devolo Mesh WiFi adapters are compatible with all Wi-Fi routers, Wi-Fi-capable devices and, of course, devolo Magic adapters. dLAN® Powerline adapters and other HomePlug AV products, including the devolo Outdoor WiFi Powerline adapters, are not supported.
Strong mesh network
All devolo units form a large, cohesive mesh network with Gigabit Wi-Fi at maximum speeds. -
The combination of Wi-Fi ac with Powerline technology enables the best distribution of Internet throughout the home. -
Strong signal over long distances
Powerline technology connects the devolo units with one another and ensures stable data transmission through ceilings and walls. -
Perfectly coordinated
Settings for data security, performance optimization and smart Wi-Fi options are automatically synchronized in the network. -
Flexible connection options
To enable additional power and LAN connections, the devolo units have multiple Gigabit LAN ports and integrated electrical sockets. -
Maximum security
devolo products are in line with the most recent encryption standards (WPA2/WPA3). This means that they ensure the protection of your data (banking standard).
- devolo Mesh Wifi 2 - Multiroom Kit - powerline adapter kit - Wi-Fi 5 - Wi-Fi 5 - wall-pluggable
- Powerline adapter kit
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, HomeGrid
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 2400 Mbps
- Auto-uplink (auto MDI/MDI-X), IPv6 support, parental control, Mesh networking, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), integrated power socket, reset button, IPv4 support, SISO technology, Airtime Fairness, 2x2 MIMO technology
- IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.3az, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v
- Power
- AC 230V (50 Hz)
- 7.6 cm x 4 cm x 15.2 cm
- Localisation
- United Kingdom
- 3-year warranty
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 2400 Mbps
- Encryption Algorithm
- WPA, WPA2, WPS, WPA3-Personal
- Status Indicators
- Power, link/activity, Wi-Fi
- 1 x HomeGrid - power Type G , LAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
- Aerial
- Internal
- Power Device
- Internal power supply
- Voltage Required
- AC 230V (50 Hz)
- 8.9 Watt
- Cables Included
- 1 x network cable - 2 m
- Localisation
- United Kingdom
- 7.6 cm
- 4 cm
- 15.2 cm
- Shipping Width
- 23.1 cm
- Shipping Depth
- 9.2 cm
- Shipping Height
- 18.8 cm
- Shipping Weight
- 1.41 kg
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
