Devolo dLAN Highspeed II 85Mbps (3 Pack)
Quicklinx: 5KJMWS00 Mfr#: 1437
The high-speed HomePlug adapters connects your computers and brings the Internet into every room of the house over the electrical wiring. Now with patented power save mode and new, clearly arranged 3-LED design.With the new devolo dLAN Highspeed Ethernet II, setting up your home network is a breeze - and you will not even have to bother with installing cables. Unlike wireless networks (WLAN), thick walls and long distances make no difference to HomePlug. The HomePlug technology uses the household electrical wiring as if it were a long network cable - offering a range of up to 200 m (656"). Fast and secure surfing on the Internet with high transfer rates of up to 85 Mbps and DESpro encryption. No complex configuration is required for installation: plug the adapter into the power outlet, connect it to your computer via the network cable and you are ready to go! Now you can expand your home network at any power outlet in the house using additional adapters. The user-friendly software allows individual password assignment for even more security.
devolo dLAN Highspeed Ethernet II Network Kit - Network Kit - bridge - desktop
Bridge
Packaged Quantity
3 (specifications are for single item)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, HomePlug 1.0
Data Transfer Rate
85 Mbps
Network / Transport Protocol
TCP/IP
Flow control, auto-uplink (auto MDI/MDI-X), full duplex mode
IEEE 802.3, IEEE 802.3u, IEEE 802.3x, HomePlug 1.0
Linux, Microsoft Windows XP, Microsoft Windows Vista (32/64 bits)
3-year warranty
Packaged Quantity
Bridge
Enclosure Type
Desktop
Wired
Data Transfer Rate
85 Mbps
TCP/IP
Status Indicators
Link OK, link/activity
1 x 10Base-T/100Base-TX - RJ-45 , 1 x HomePlug 1.0
Internal power supply
4.5 Watt
3 x network cable
Limited warranty - 3 years
10 - 90%
