The dLAN Eco Line is devolo's dLAN home network product line for a particularly simple and energy-saving network at home. With the Dynamic PowerSave technology, these adapters flexibly adjust their energy consumption according to the connected device. dLAN 500 duo+ has two network ports for the simple connection of two network-compatible devices such as computers or consumer electronics, directly on the adapter. The ultra-compact design enables a flexible and unobtrusive positioning. In contrast to the classic duo model, the duo+ has an integrated electrical socket and a mains filter that improves the dLAN powerline transmission capacity even more.
- devolo dLAN 500 duo+ - powerline adapter - wall-pluggable
- Powerline adapter
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, HomePlug AV (HPAV)
- Data Transfer Rate
- 500 Mbps
- CSMA/CA
- Auto-uplink (auto MDI/MDI-X), integrated power socket
- IEEE 802.3, IEEE 802.3u, IEEE 802.3x, HomePlug AV
- Power
- AC 230V (50/60 Hz)
- 5.5 cm x 4 cm x 11 cm
- System Requirements
- Linux, Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows Vista / XP / 7 / 8 (64-bit versions)
- Localisation
- United Kingdom
- 3-year warranty
- Powerline adapter
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wired
- 500 Mbps
- CSMA/CA
- Encryption Algorithm
- 128-bit AES
- Status Indicators
- Power
Line Properties
- Line Coding Format
- 64 QAM, 256 QAM, BPSK, QPSK, OFDM, 1024 QAM, 4096 QAM
- 1 x HomePlug AV , LAN: 2 x 10Base-T/100Base-TX - RJ-45
- Power Device
- Internal power supply
- Voltage Required
- 3.5 Watt
- Cables Included
- 1 x network cable
- Localisation
- United Kingdom
- OS Required
- 5.5 cm
- 4 cm
- 11 cm
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
