Devolo dLAN 500 AVplus Single Adapter
Quicklinx: 7DNJWS00 Mfr#: 1648
Make use of the home network of the future today, and connect computers and consumer electronics via the household power line - with the dLAN 500 AVplus! All devices can be connected to each other and the Internet quickly, easily and securely. dLAN reaches speeds of up to 500 Mbps and features even higher performance than network cables or WLAN-and that without WLAN picture stutter or the need to route cables. And with its integrated electrical socket, no power outlet goes to waste.
devolo dLAN 500 AVplus - powerline adapter - wall-pluggable
Powerline adapter
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV)
Data Transfer Rate
500 Mbps
Network / Transport Protocol
CSMA/CA
Auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, HomePlug AV
AC 230V (50 Hz)
6.6 cm x 4.2 cm x 13 cm
Apple MacOS X, Microsoft Windows XP, Microsoft Windows Vista (32/64 bits), Ubuntu, Microsoft Windows 7 (32/64 bits)
United Kingdom
3-year warranty
Powerline adapter
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
500 Mbps
CSMA/CA
Encryption Algorithm
128-bit AES
Status Indicators
Power, link/activity
Line Properties
Line Coding Format
64 QAM, 256 QAM, BPSK, QPSK, OFDM, 1024 QAM, 4096 QAM
1 x HomePlug AV - power , 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Internal power supply
AC 230V (50 Hz)
5 Watt
1 x network cable
United Kingdom
Software Included
Drivers & Utilities
6.6 cm
4.2 cm
13 cm
Limited warranty - 3 years
10 - 90% (non-condensing)
