- devolo dLAN 200 AV Wireless N - Starter Kit - powerline adapter - Wi-Fi - wall-mountable
- Powerline adapter - 3-port switch (integrated)
- Enclosure Type
- Wall-mountable
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV)
- Frequency Band
- 2.4 GHz
- TCP/IP, UDP/IP, ICMP/IP, ARP, DHCP, CSMA/CA, CSMA/CD
- Remote Management Protocol
- HTTP
- Auto-uplink (auto MDI/MDI-X), manageable
- IEEE 802.3, IEEE 802.3u, IEEE 802.11, IEEE 802.1D, IEEE 802.11b, IEEE 802.3x, IEEE 802.11g, IEEE 802.11e, IEEE 802.11n, HomePlug AV
- Power
- AC 120/230 V (50/60 Hz)
- 6.8 cm x 4.9 cm x 11 cm
- 400 g
- System Requirements
- Linux, Apple MacOS X, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
- Localisation
- United Kingdom
- 3-year warranty
- Enclosure Type
- Wall-mountable
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- Max Range Open Space
- 300 m
- HTTP
- Encryption Algorithm
- AES, TKIP, WPA, WPA2, 128-bit AES
- Status Indicators
- Power, link OK, link/activity
Line Properties
- Line Coding Format
- 64 QAM, 256 QAM, BPSK, QPSK, 1024 QAM
- WAN: 1 x HomePlug AV , LAN: 3 x 10Base-T/100Base-TX - RJ-45
- Power Device
- Internal power supply
- Voltage Required
- 7 Watt
- Included Accessories
- HomePlug AV Ethernet Adapter
- Localisation
- United Kingdom
- Software Included
- Drivers & Utilities
- OS Required
- 6.8 cm
- 4.9 cm
- 11 cm
- 400 g
- Limited warranty - 3 years , Technical support - phone consulting , Product info support - e-mail consulting
- 0 °C
- 40 °C
- 10 - 90%
