dLAN 500 WiFi technology combines the latest technology and unobtrusive design with the best Internet connection.
As a Powerline adapter, the dLAN 500 WiFi uses internal power lines as a long cable, thereby bringing the Internet to any room.
The integrated wireless LAN also provides complete Internet coverage to every nook and cranny.
Smartphones, tablets and laptops have full-strength coverage right from the start without any problems. An additional terminal device can be connected at any time (such as a Smart TV or game console) using the additional fast Ethernet connection. Now, smartphones, tablets and laptops are automatically connected to the Internet - the best Wi-Fi reception in any room or floor automatically! And the compact and unobtrusive design can be integrated into any residential interior without looking out of place. The dLAN 500 WiFi from devolo brings the future to your home.
- devolo dLAN 500 WiFi - Starter Kit - powerline adapter kit - Wi-Fi - wall-pluggable
- Powerline adapter kit
- Packaged Quantity
- 2 (specifications are for single item)
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV)
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 500 Mbps
- CSMA/CA
- Auto-uplink (auto MDI/MDI-X), MAC address filtering, Wi-Fi Protected Setup (WPS)
- IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.11b, IEEE 802.3x, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, HomePlug AV, IEEE 1901
- Power
- AC 230V (50 Hz)
- 6.8 cm x 4.1 cm x 6.8 cm
- System Requirements
- Linux, Apple MacOS X, Android, Apple iOS, Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows Vista / XP / 7 / 8 (64-bit versions)
- Localisation
- United Kingdom
- 3-year warranty
- Packaged Quantity
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 500 Mbps
- Max Range Open Space
- 300 m
- CSMA/CA
- Encryption Algorithm
- WPA, WPA2, 128-bit AES, WEP
- Status Indicators
- WLAN, link/activity
Line Properties
- Line Coding Format
- 64 QAM, 256 QAM, BPSK, QPSK, 1024 QAM, 4096 QAM
- LAN: 1 x 10Base-T/100Base-TX - RJ-45 , 1 x HomePlug AV , Antenna: 1 x
- Power Device
- Internal power supply
- Voltage Required
- AC 230V (50 Hz)
- 5 Watt
- Cables Included
- 1 x network cable
- Localisation
- United Kingdom
- OS Required
- 6.8 cm
- 4.1 cm
- 6.8 cm
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
