Devolo dLAN® 200 AVplus Network Kit
Quicklinx: 87DKWS00 Mfr#: 1867
The HomePlug AV adapter from Devolo provides extra convenience for your private home network with its integrated electrical socket and mains filter. The integrated electrical socket enables additional terminal devices or multiple sockets to be connected to the adapter just like to a normal wall socket. No power supply is lost. And the integrated filter significantly improves data transmission in the home network.
The dLAN 200 AVplus transmits bandwidthintensive data easily and securely over the existing electrical wiring - without installation effort. In addition, the "Quality of Service" function prioritizes the bandwidth requirement of the data traffic, which has a speed of 200 Mbps, thus ensuring maximum voice and video reproduction. TV and video images are received and displayed with absolute smoothness. QoS also guarantees the clear, instant reproduction of voice data, even when other applications are running on the network at the same time. QoS makes your network a joy to use!
  • Perfect network performance
    The HomePlug AV adapter from devolo provides extra convenience for your private home network with its integrated electrical socket and mains filter. The integrated electrical socket enables additional terminal devices or multiple sockets to be connected to the adapter just like to a normal wall socket. No power supply is lost. And the integrated filter significantly improves data transmission in the home network. The dLAN 200 AVplus transmits bandwidth intensive data easily and securely over the existing electrical wiring - without installation effort. In addition, the "Quality of Service" function prioritizes the bandwidth requirement of the data traffic, which has a speed of 200 Mbps, thus ensuring maximum voice and video reproduction. TV and video images are received and displayed with absolute smoothness. QoS also guarantees the clear, instant reproduction of voice data, even when other applications are running on the network at the same time. QoS makes your network a joy to use!
  • Security
    Attain maximum data security via the electrical wiring thanks to the 128-bit AES (Advanced Encryption Standard) encryption. The encryption is simply activated by the push of a button. No additional software is required. Locking down your network couldn't be easier!
  • Patented power saving-mode
    This is due to its patented power saving mode modus, which reduces energy consumption automatically by 30% when the computers on the dLAN network or other connected equipment are switched off for a period of time. And power savings means cost savings!
devolo dLAN 200 AVplus Network Kit - Network Kit - powerline adapter - desktop
Powerline adapter
Enclosure Type
Desktop
Ethernet, Fast Ethernet, HomePlug AV (HPAV)
Data Transfer Rate
200 Mbps
Network / Transport Protocol
TCP/IP, CSMA/CA
Auto-uplink (auto MDI/MDI-X), Quality of Service (QoS), integrated power socket
IEEE 802.3, IEEE 802.3u, IEEE 802.3x, HomePlug AV
6.6 cm x 4.2 cm x 13 cm
240 g
Linux, Apple MacOS X, Microsoft Windows XP, Microsoft Windows Vista, Microsoft Windows Vista (64-bit versions)
United Kingdom
3-year warranty
Powerline adapter
Enclosure Type
Desktop
Wired
Data Transfer Rate
200 Mbps
TCP/IP, CSMA/CA
Encryption Algorithm
128-bit AES
IEEE 802.3, IEEE 802.3u, IEEE 802.3x, HomePlug AV, EN55022, EN 60950-1, WEEE, EN 50412
Status Indicators
Power, link OK, link/activity
Line Properties
Line Coding Format
64 QAM, 256 QAM, BPSK, QPSK, OFDM, 1024 QAM
1 x HomePlug AV - power , 1 x 10Base-T/100Base-TX - RJ-45
Internal power supply
5 Watt
1 x network cable
United Kingdom
Software Included
Drivers & Utilities, devolo Easyclean, devolo Easyshare, devolo Informer
6.6 cm
4.2 cm
13 cm
240 g
Limited warranty - 3 years
10 - 90% (non-condensing)
