Easily manage your office network with 1GbE and 10GbE switches that offer enterprise-class features and intuitive, GUI-based management.
Robust capacity
With support for up to 16,000 MAC addresses, 12 LAG groups, 8 priority queues per port, and 4,096 virtual interfaces (VLANs), this switch is designed to handle extensive networking demands efficiently. -
Comprehensive connectivity
Offers a total of 48 10/100/1000 ports for high-speed connectivity along with 4 10 Gigabit SFP+ ports, ensuring versatile connection options for a wide range of devices and network configurations. -
Enhanced power delivery
Features Power over Ethernet Plus (PoE+) across 12 ports and a total power supply of 525 watts, facilitating flexible installation and power management of PoE devices like IP cameras and VoIP phones. -
Advanced management features
Equipped with Layer 2+ switching capabilities and manageable via CLI, HTTP, RMON, and SNMP protocols, this switch offers sophisticated control and monitoring options for network administrators. -
Reliable environmental adaptability
Designed to operate within a wide range of temperatures and humidity, ensuring reliable performance in various environmental conditions without compromising on efficiency.
- Dell Networking X1052P - switch - 48 ports - Managed - rack-mountable
- Switch - 48 ports - L2+ - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 48 x 10/100/1000 + 4 x 10 Gigabit SFP+
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 360 W
- Performance
- Switching fabric bandwidth: 176 Gbps , Forwarding performance: 131 Mpps
- Capacity
- MAC addresses: 16000 , LAG groups: 12 , Priority queues per port: 8 , Virtual interfaces (VLANs): 4096 , Maximum member ports per LAG: 8
- MAC Address Table Size
- 16K entries
- Remote Management Protocol
- SNMP 1, SNMP 2, RMON, SNMP 3, HTTP, CLI
- Auto-negotiation, VLAN support, Syslog support, port mirroring, Broadcast Storm Control, IPv6 support, SNTP support, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Virtual Cable Test (VCT) technology, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), DHCP server, MLD snooping, Uni-Directional Link Detection (UDLD), DNS server, LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), SNMP trap, static routing, GARP VLAN Registration Protocol (GVRP), SNMP support, ARP inspection, Head of Line Blocking Prevention, Back Pressure Support, Proprietary Protocol Filtering
- IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ac, IEEE 802.1s, IEEE 802.1v, IEEE 802.1ab (LLDP)
- Power
- AC 120/230 V (50/60 Hz)
- 43.4 cm x 40.7 cm x 43.5 cm
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 360 W
- Performance
- Capacity
- 16K entries
- Authentication Method
- RADIUS, TACACS+
- 48 x 1000Base-T 12 ports (PoE+) / 24 ports (PoE) , 4 x 10Gbit LAN SFP+ , 1 x USB Type A management , 1 x micro-USB management
- Power Device
- Internal power supply
- Power Provided
- 525 Watt
- Voltage Required
- 82 Watt
- 43.4 cm
- 40.7 cm
- 43.5 cm
- Limited warranty - lifetime
- 0 °C
- 45 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £4.30 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.80 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £14.24 |
