Brand
Dell Networking N1548P Switch 48 Ports Managed Rack-Mountable
Quicklinx: CH6WWS00 Mfr#: 210-AEWB
Type: Gigabit Ethernet
Ports: 48
Managed: Yes
POE: PoE+
£2,586.21 ex VAT
£3,103.45 inc VAT
The N1500 switch series offers a power-efficient Gigabit Ethernet (GbE) network-access switching solution with integrated 10GbE uplinks. The N1500 switch series has high-performance capabilities and wire-speed performance, utilizing a non-blocking architecture to handle unexpected traffic loads easily. These switches offer simple management and scalability via a 40Gbps (full-duplex) high-availability stacking architecture that allows management of up to four switches from a single IP address.
  • Designed for efficiency
    Built to help keep operating costs down, the N1500 Series can operate at temperatures up to 113°F (45°C) to help reduce cooling costs.
  • Simplify management with advanced features
    The Dell Networking N1500 Series delivers easy deployment, outstanding interoperability and a level learning curve for network administrators.
  • Deploy with confidence at any scale
    With high throughput and capacity to handle unexpected workloads, the N1500 Series switches are ideal solutions for fast-growing GbE networks that require high-density aggregation with seamless redundancy and availability.
Dell Networking N1548P - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - L2+ - Managed - stackable
Enclosure Type
Front to back airflow rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 4 x 10 Gigabit SFP+
Power Over Ethernet (PoE)
PoE+
PoE Budget
30.8 W
Performance
Switching fabric bandwidth: 176 Gbps , Forwarding performance: 164 Mpps
Virtual interfaces (VLANs): 512 , ARP entries: 1024 , NDP entries: 400 , Priority queues per port: 8 , IPv4 routes (static): 256 , IPv6 routes (static): 128 , IPv4 routes (dynamic): 256 , VLAN routing interfaces: 128 , ACL: 100 , Max ACL rules system-wide: 2048 , Maximum rules per ACL: 1023 , Maximum ACL rules per interface (IPv4) ingress rules: 1023 , Maximum ACL rules per interface (IPv4) egress rules: 1023 , Maximum ACL rules per interface (IPv6) ingress rules: 512 , Maximum ACL rules per interface (IPv6) egress rules: 509 , Maximum VLAN interfaces with ACLs applied: 24 , Maximum dynamic ports per switch stack: 144 , Maximum member ports per LAG: 8 , MAC addresses: 16000
MAC Address Table Size
16000 entries
Routing Protocol
RIP-1, RIP-2, static IPv4 routing, static IPv6 routing
Remote Management Protocol
Telnet, TFTP
Auto-negotiation, auto-uplink (auto MDI/MDI-X), port mirroring, Broadcast Storm Control, redundant fans
44 cm x 38.7 cm x 4.32 cm
7 kg
Enclosure Type
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
30.8 W
Performance
16000 entries
Routing Protocol
Telnet, TFTP
Encryption Algorithm
MD5, AES, SSL, TLS
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
RAM
1 GB
Flash Memory
256 MB
48 x Gigabit LAN RJ-45 , 4 x 10Gbit LAN SFP+ , 1 x serial (RS-232) RJ-45 management , 1 x USB Type A
Internal power supply
Installed Qty
1
Power Provided
600 Watt
Rack Mounting Kit
Included
FCC Class A certified, cUL, GS, RoHS, WEEE, REACH, ICES Class A, VCCI Class A, EAC, CCC Class A
44 cm
38.7 cm
4.32 cm
7 kg
Limited warranty - lifetime
45 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
65 °C
CH6W Dell SFP+ Transceiver Module 10 Gigabit Ethernet - 10GBase In Stock £186.02
Ports: 48
Managed: Yes
POE: PoE+
Brand: Dell
Price Range Ex VAT: £1500+
