The Dell Wireless Laser Mouse is your solution for a high-precision wireless Windows 8 experience, designed to help you get more done, in more places. It features excellent battery life that allows for reliable performance. The mouse also features laser tracking that helps for smooth tracking on almost any surface, and with the Logitech Unifying Technology you'll have a reliable wireless connection and Nano dongle that easily pairs with other Logitech Unifying devices.
Wireless convenience
Reduce cable clutter with a wireless mouse that communicates with your PC through a nano-USB receiver. Plug in this compact receiver once and forget about it. -
Dell Unifying Software by Logitech
Enjoy the freedom and flexibility of the Dell Unifying USB Receiver. Manage up to six other unifying peripheral devices such as a keyboard, number pad or other mice for easy transitions between home and the office. -
Windows 8 gesture controls
Work efficiently in Windows 8. Scroll up, down, left or right with the mouse wheel to navigate Windows 8 tiles, and use the side buttons to access the Windows 8 Charms Bar. Stick to the familiar scroll wheel for use with other Windows operating systems. -
Comfortable shape
The Dell Wireless Mouse features a progressive design that feels as good in your hand as it looks on your desk. Its sleek design and long battery life from 2 AA batteries (sold separately) enable long, comfortable sessions in front of your PC or tablet. -
Precision laser tracking
Navigate with smooth laser tracking across your screen courtesy of a precision laser that works well on almost any surface.
- Dell WM514 - mouse - 2.4 GHz
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Laser
- Buttons Qty
- 6
- Scrolling wheel, Nano wireless receiver
- Battery
- AA type
- Mouse
- Wireless Receiver
Input Device
- Wireless
- Interface
- 2.4 GHz
- Laser
- Buttons Qty
- 6
- 1 x USB - 4 pin USB Type A
- AA type
