The Dell optical mouse - MS116 features optical LED tracking and wired connectivity providing a stellar performance day after day. Improve your productivity at the office or at home - the Dell optical mouse will help keep you on task with accurate 1000 DPI optical tracking.
Reliable performance day after day
The Dell optical mouse - MS116 features optical LED tracking and wired connectivity providing a stellar performance day after day. Improve your productivity at the office or at home - the Dell optical mouse will help keep you on task with accurate 1000 DPI optical tracking. -
Comfort that lasts
Designed for comfortable use over extended periods of time, the Dell optical mouse is your desktop partner. Shaped and sized to fit the contours of your hand with 2 buttons and a scroll wheel, the Dell optical mouse makes it easy to navigate through on - screen projects. -
Compatible with practically any system
The Dell optical mouse is compatible with almost any system that has a USB port. Use one mouse in the office and keep another at home. -
Plug and play convenience
Simply plug the Dell optical mouse into any available USB port and get to work - it's that easy. -
At home or in the office
The Dell optical mouse is the perfect choice for either home or office use - wherever reliability, comfort and convenience are objectives. -
Contemporary aesthetic
With a contemporary design aesthetic, the Dell optical mouse - MS116 seamlessly fits into any desktop environment.
 - Dell MS116 - mouse - USB - black
 - Mouse
- Connectivity Technology
 - Wired - USB
 - Black
 - 413 g
- Movement Detection Technology
 - Optical
- Buttons Qty
 - 2
- Movement Resolution
 - 1000 dpi
- Cable Length
 - 1.8 m
 - 1-year warranty
 - Mouse
 - 413 g
 - Black
Input Device
 - Wired
- Interface
 - USB
 - Optical
- Buttons Qty
 - 2
 - 1000 dpi
- Cable Length
 - 1.8 m
 - 1 x USB
 - Limited warranty - 1 year
