Dell UltraSharp 24" 1920 x 1080 8ms LED-backlit LCD monitor
Quicklinx: G17BWS00 Mfr#: DELL-U2419H
Experience superb screen performance on this 23.8" monitor in an innovative, stylish thin design. Color consistency comes standard: your UltraSharp monitor is factory calibrated at 99% sRGB coverage to an accuracy of Delta-E less than 2, for precise hues right out of the box. Plus with 99% Rec709 and 85% DCI-P3 color coverage, you'll see true-to-life colors in video formats.
Always the best view: see consistent, vibrant colors across a wide viewing angle enabled by In-Plane Switching (IPS) technology. With a stylishly thin panel profile (only 6.5mm at its thinnest) and a compact base that's approximately 30% smaller than its predecessor, you can free up valuable desk space. Adjust to your comfort: pivot, tilt, swivel and adjust the height of your monitor for a comfortable setup all day long. Our improved design, with the hinge on the riser, makes it easier to adjust while keeping the riser in the same place.
  • Impressive screen performance
    Experience superb screen clarity with Full HD (1920x1080) resolution on a 23.8" screen.
  • Color consistency comes standard
    Your UltraSharp monitor is factory calibrated at 99% sRGB coverage to an accuracy of Delta-E less than 2, for precise hues right out of the box. Plus with 99% Rec709 and 85% DCI-P3 color coverage, you'll see true-to-life colors in video formats.
  • Always the best view
    See consistent, vibrant colors across a wide viewing angle enabled by In-Plane Switching (IPS) technology.
  • More room to work
  • Adjust to your comfort
    Pivot, tilt, swivel and adjust the height of your monitor for a comfortable setup all day long. The improved design, with the hinge on the riser, makes it easier to adjust while keeping the riser in the same place.
  • Clean and clutter-free
    Focus on your work while hiding away cable clutter with an improved cable management design.
  • Expand your efficiency
    The virtually borderless design featuring InfinityEdge lets you enjoy a nearly seamless view of your content across multiple monitors. And, with dual monitors, you can increase your productivity by up to 18%3 .
  • More ways to multitask
    Easily organize multiple applications using predefined templates or a customized template with the Easy Arrange feature on Dell Display Manager software. Plus, you can conveniently tile your applications across a multi-monitor setup.
  • Get right to work
    With Auto-restore on Dell Display Manager, you can disconnect, reconnect and all of your applications will be in the same position where you left off.
Dell UltraSharp U2419H - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Consumption per Year
21 kWh
Power Consumption (On mode)
12.3 W
Daisy Chaining
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (fast), 8 ms (normal)
Colour Support
16.7 million colours
Colour Gamut
99% Rec 709, 99.9% sRGB, 85% DCI-P3
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
53.85 cm x 16.5 cm x 34.84 cm
Environmental Standards
ENERGY STAR Qualified
Carbon Footprint
545 kg carbon emissions
RoHS, NFPA 99, BFR-free, PVC-free
Bundled Services
3-Years Advanced Exchange Service and Premium Panel Guarantee
Latitude 7400 2-in-1; XPS 13 9380, 15 9570
Display Type
21 kWh
Diagonal Size
24"
Viewable Size
23.8"
Daisy Chaining
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
92.5
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Mercury free, Dell Easy Arrange, arsenic free
53.85 cm x 16.5 cm x 34.84 cm - with stand
DisplayPort (HDCP) , DisplayPort output (MST) , HDMI (HDCP) , 2 x USB 3.0 downstream , 2 x USB 3.0 downstream with Battery Charging 1.2 , USB 3.0 upstream , Audio line-out (mini-jack)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
80
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support, anti-theft stand lock slot
1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x SuperSpeed USB cable
Security Slot Type
Kensington security slot
Input Voltage
12.3 W
Power Consumption (Typical)
17 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 53.85 cm - depth: 3.9 cm - height: 31.37 cm - weight: 3.14 kg , With stand - width: 53.85 cm - depth: 16.5 cm - height: 34.84 cm
Sustainability Information
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
119
Manufacturing (kg CO2e)
379
Logistics (kg CO2e)
50
Use (kg CO2e)
107
EOL (kg CO2e)
3
Total Carbon w/o Use Phase (kg CO2e)
432
PAIA Version
9/5/2018
Bundled Services
10 - 80% (non-condensing)
Dell Latitude 7400 2-in-1 , Dell XPS 13 9380, 15 9570
