Dell Dell 22 Monitor - E2222H - 54.48cm (21.5")
Quicklinx: HRHSWS00 Mfr#: E2222H
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 8ms
Interfaces: HDMI, VGA (HD-15)
£45.89 ex VAT
£55.06 inc VAT
Maximize space and view your screen with fewer distractions with this 21.5" Full HD monitor featuring three-sided slim bezels and a compact stand base.
Dell SE2222H - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/557072
Energy Class
Class E
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.249 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1
Response Time
12 ms (grey-to-grey typical), 8 ms (grey-to-grey fast)
Colour Support
16.7 million colours
Colour Gamut
72% sRGB (CIE 1931)
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare 3H hardness
Voltage
AC 100-240 V (50/60 Hz)
50.426 cm x 17.881 cm x 38.408 cm
2.67 kg
Carbon Footprint
492 kg carbon emissions
TUV, RoHS, BFR-free, HDCP 1.4, PVC-free
1-year warranty with Advanced Exchange Service
Bundled Services
3 years Advanced Exchange Service and Limited Hardware Warranty
Display Type
Energy Class
Class E
Diagonal Size
22"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.249 mm
Pixel Per Inch
103
Brightness
250 cd/m²
Contrast Ratio
3000:1
Colour Support
Colour Gamut
72% sRGB (CIE 1931)
Response Time
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
LED edgelight system, Flicker Free technology, Dell Easy Arrange, Dell ComfortView, arsenic free, Low Blue Light technology, 3-sided bezeless
50.426 cm x 17.881 cm x 38.408 cm - with stand
2.67 kg
HDMI (HDCP 1.4) , VGA
Mechanical
Tilt
Tilt Angle
-5/+21
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
VESA screw cover, stand base, stand riser
1 x HDMI cable
Security Slot Type
Kensington security slot
Input Voltage
14.1 kWh/1000h
Power Consumption (Max)
22 watt
Power Consumption Stand by
0.3 watt
Power Consumption (Off Mode)
0.3 watt
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand - width: 50.426 cm - depth: 17.881 cm - height: 38.408 cm - weight: 2.67 kg , Without stand - width: 50.426 cm - depth: 4.921 cm - height: 29.538 cm - weight: 2.34 kg
Shipping Weight
4.4 kg
Sustainability Information
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
129
Manufacturing (kg CO2e)
319
Logistics (kg CO2e)
19
Use (kg CO2e)
152
EOL (kg CO2e)
2
Total Carbon w/o Use Phase (kg CO2e)
340
PAIA Version
1.3.2
Limited warranty - 1 year
Bundled Services
10 - 80% (non-condensing)
Diagonal Size: 22in
Response Time: 8ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Dell
Stock Status: While stocks last
Stock Status: Clearance
