The USB 3.0 E-Port Replicator from Dell is a space-saving port replicator suitable for home and office environment which enables connection to your desk peripherals. This docking station includes a latest USB 3.0 technology enabled by Intel in Ivy Bridge. It has replaced the 2 USB 2.0 connectors with the USB 3.0. Plus, the Display Port 1.2 adds the ability to daisy chain displays (4 displays via 1 connector). Also it offers an adaptor complexity reduction. This product has been tested and validated on Dell systems. It is supported by Dell Technical Support when used with a Dell system. Please note this is the EU version.
- Dell E-Port Replicator - port replicator
- Product Type
- Port replicator
- 20 cm x 17 cm x 5.36 cm
- 780 g
- Power
- Power adapter - external 130 Watt Power Provided
- Designed For
- Latitude E4200, E4300, E4310, E5250, E5270, E5400, E5410, E5420, E5430, E5440, E5450, E5460, E5470, E5500, E5510, E5520, E5530, E5540, E5550, E5570, E6220, E6230, E6320, E6330, E6400, E6410, E6420, E6430, E6430S, E6440, E6500, E6510, E6520, E6530, E6540, E7240, E7250, E7270, E7440, E7450, E7470
- Product Type
- Port replicator
- 20 cm
- 17 cm
- 5.36 cm
- 780 g
- 1 x display / video - DisplayPort , 1 x display / video - DVI-Digital - 18+1 pin digital DVI (Single-Link) , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 2 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x eSATA / USB 2.0 - 11 pin USB/eSATA , 3 x USB 2.0 - 4 pin USB Type A , 1 x network - RJ-45 , 1 x microphone - input - mini-phone 3.5 mm , 1 x audio - output - mini-phone stereo 3.5 mm
- Security Slot Type
- Kensington security slot
- Power Device
- Power Provided
- 130 Watt
- Designed For
- Dell Latitude E4200, E4300, E4310, E5250, E5270, E5400, E5410, E5420, E5430, E5440, E5450, E5460, E5470, E5500, E5510, E5520, E5530, E5540, E5550, E5570, E6220, E6230, E6320, E6330, E6400, E6400 ATG, E6400 XFR, E6410, E6410 ATG, E6420, E6420 ATG, E6420 XFR, E6430, E6430 ATG, E6430S, E6440, E6500, E6510, E6520, E6530, E6540, E7240, E7250, E7270, E7440, E7450, E7470
