Dell P3421W 34.14" 3440x1440 5ms HDMI DisplayPort USB-C IPS LED Curved Monitor
Quicklinx: GRPMWS00 Mfr#: DELL-P3421WM
Diagonal Size: 34in
Max Resolution: 3440 x 1440
Response Time: 5ms
Speakers: None
Interfaces: HDMI, DisplayPort, USB-C
£474.99 ex VAT
£569.98 inc VAT
Productivity that pulls you inFocus like never before on this immersive, curved monitor with a WQHD screen, improved cable management and up to 65W of power delivery.
  • Immersive productivity
    See more and achieve more at home or in the office on this ultrawide WQHD (3440 x 1440) curved screen. With more onscreen space, you can multitask effectively - without the need for a dual monitor setup. Plus, the three-sided, ultra-thin borders let you dive in without distraction.
  • All-encompassing view
    The 3800 R screen curvature creates an ultrawide 21:9 field of view, minimizes reflection and offers near uniform visual focus, for a more comfortable visual experience over extended viewing periods.
  • Unparalleled focus
    Focus more on your work at home or in the office with a panoramic view, extended peripheral vision and incredible depth.
  • Consistent views
    Expect seamless, wide viewing angles no matter where you sit, thanks to IPS technology.
  • Designed with you in mind
    Navigate the menu and adjust screen settings with the easy-to-use joystick control.
  • Beauty meets function
    This sleek monitor features a small base and an improved cable management design that hides cables in the monitor riser, for a clutter free desk space at your office or home office.
  • Comfort is key
    Tilt, swivel and adjust the height of your monitor to a maximum of 150 mm because you should be comfortable however and wherever you work.
  • Easy on the eyes
    Optimize eye comfort with a flicker-free screen and ComfortView, a feature that reduces harmful blue light emissions.
  • The power of USB-C
    Get high power delivery via USB-C, so you can keep your laptop battery full and enjoy uninterrupted productivity. This single-cable solution also saves much workspace setup time, reduces cable clutter and transmits power, data and audio - all at once.
  • Multitask efficiently
    Connect two PCs to the monitor and display the content at the same time with Picture-by-Picture (PbP) and Picture-in-Picture (PiP) features. Use the KVM (keyboard, video and mouse) feature to edit content from two different PCs using a single keyboard and mouse.
  • Quick convenience
    Plug in whatever you need and keep it in reach with the two, SuperSpeed USB 5 Gbps (USB 3.2 Gen1) quick access ports.
Dell P3421WM - LED monitor - curved - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class F
Power Consumption (On mode)
31.5 W
Curved Screen
KVM Switch, USB 3.2 Gen 1 hub, USB PD 65 Watt
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
WQHD 3440 x 1440 at 60 Hz
Pixel Pitch
0.2325 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
1.07 billion colours
Colour Gamut
99% sRGB
Input Connectors
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (lowest position)
81.57 cm x 23.74 cm x 39.11 cm
10.8 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified EPEAT Gold
DisplayPort 1.2, HDCP 2.3
Bundled Services
3 years Advanced Exchange Basic Warranty
Latitude 3320, 3420, 3520, 5320, 5320 2-in-1, 5420, 5421, 5520, 5521, 7320, 7420, 7520, 9420, 9520, 9520 2-in-1; OptiPlex 3080, 3090, 5090, 7090; Precision 3240, 3450, 3650; Vostro 13 5310, 14 5410, 15 5510, 15 7510, 5415, 5515, 7500; XPS 13 9310, 15 9510
Display Type
Energy Class
Class F
Diagonal Size
34"
Curved Screen
Yes (3800R)
Built-in Devices
USB Power Delivery
65 Watt
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.2325 mm
Pixel Per Inch
109
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
99% sRGB
Response Time
Vertical Refresh Rate
48 - 85 Hz
Horizontal Refresh Rate
30 - 85 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Picture by picture, Flicker Free technology, Dell Easy Arrange, Dell ComfortView, Picture-in-Picture, narrow-bezel design, 8-bit + A-FRC Colour Depth, 3-sided bezeless
81.57 cm x 23.74 cm x 39.11 cm - with stand (lowest position)
10.8 kg
HDMI , DisplayPort 1.2 , USB-C upstream/DisplayPort Alt Mode with Power Delivery (power up to 65W) , USB 3.2 Gen 1 upstream , 2 x USB 3.2 Gen 1 downstream , 2 x USB 2.0 downstream
Mechanical
Tilt Angle
-5/+21
Swivel Angle
60
Height Adjustment
150 mm
VESA interface support, security lock
1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x HDMI cable , 1 x USB-C 3.2 Gen 1 cable , 1 x USB 3.2 Gen 1 upstream cable
Input Voltage
31.5 W
31.5 kWh/1000h
Power Consumption (Typical)
31.5 Watt
Power Consumption (Max)
126 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.2 Watt
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand (lowest position) - width: 81.57 cm - depth: 23.74 cm - height: 39.11 cm - weight: 10.8 kg , Without stand - width: 81.57 cm - depth: 5.81 cm - height: 36.54 cm - weight: 6.7 kg
Shipping Weight
14.9 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
ENERGY STAR Version
8.0
Bundled Services
10 - 90% (non-condensing)
Dell Latitude 3320, 3420, 3520, 5320, 5320 2-in-1, 5420, 5421, 5520, 5521, 7320, 7320 Detachable, 7420, 7520, 9420, 9520, 9520 2-in-1 , Dell OptiPlex 3080, 3090, 5090, 7090 , Dell Precision 3240 Compact, 3450 Small Form Factor, 3650 Tower , Dell Vostro 13 5310, 14 5410, 15 5510, 15 7510, 5415, 5515, 7500 , Dell XPS 13 9310, 13 9310 2-in-1, 15 9510
GRPM Dell SB521A Magnetic Sound bar In Stock £28.02
GRPM Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £58.86
GRPM Dell Thunderbolt Dock WD22TB4 180W In Stock £188.18
GRPM Dell Dell Pro Wireless Mouse MS5120W Black In Stock £23.75
Diagonal Size: 34in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: DisplayPort
Interfaces: USB-C
Brand: Dell
