Connect your mouse conveniently via Wi-Fi or Bluetooth with any PC and enhance your productivity with programmable shortcut buttons and a long battery life.
Connect seamlessly
The dual-mode connectivity incorporates a 2.4 GHz wireless and a Bluetooth 5.0 connection so you can pair and connect to almost any PC via your preferred mode. -
Easy pairing
Pair your mouse to your Windows laptop via Bluetooth instantly using Microsoft Swift Pair, so you do not need to configure in Windows settings every time. -
Built to last
Work for up to 36 months on a single battery, so you can forget about having to recharge daily, weekly or even monthly. This lets you get on with your tasks smoothly without having to be concerned with battery replacements. -
Precise tracking
A 1600 dpi sensor ensures this Dell wireless mouse handles high-resolution screens easily. Its optical sensor offers accurate tracking and is ideal on most desk surfaces. -
Quick access
Intuitively positioned shortcut buttons allow easy navigation across web pages and applications. Browse back and forth efficiently between pages onscreen effortlessly.
- Dell MS5120W - mouse - 2.4 GHz, Bluetooth 5.0 - black
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz, Bluetooth 5.0
- Bundled Services
- 3 years NBD Advance Exchange
- Black
- 6.15 cm x 10.45 cm x 3.83 cm
- 73.7 g
- Movement Detection Technology
- Optical
- Buttons Qty
- 7
- Movement Resolution
- 1600 dpi
- Swift Pair
- Battery
- AA type
- OS Required
- Linux, Android, Google Chrome OS, Microsoft Windows 7 / 8 / 8.1 / 10
- Mouse
- Bundled Services
- 6.15 cm
- 10.45 cm
- 3.83 cm
- 73.7 g
- Black
Input Device
- Wireless
- Interface
- Optical
- Buttons Qty
- 7
- 1600 dpi
- Swift Pair
- Included Accessories
- 1 AA battery
- AA type
- Run Time (Up To)
- 36 months
- OS Required
