Productivity that pulls you inFocus like never before on this immersive, curved monitor with a WQHD screen, improved cable management and up to 65W of power delivery.
Immersive productivity
See more and achieve more at home or in the office on this ultrawide WQHD (3440 x 1440) curved screen. With more onscreen space, you can multitask effectively - without the need for a dual monitor setup. Plus, the three-sided, ultra-thin borders let you dive in without distraction. -
All-encompassing view
The 3800 R screen curvature creates an ultrawide 21:9 field of view, minimizes reflection and offers near uniform visual focus, for a more comfortable visual experience over extended viewing periods. -
Unparalleled focus
Focus more on your work at home or in the office with a panoramic view, extended peripheral vision and incredible depth. -
Consistent views
Expect seamless, wide viewing angles no matter where you sit, thanks to IPS technology. -
Designed with you in mind
Navigate the menu and adjust screen settings with the easy-to-use joystick control. -
Beauty meets function
This sleek monitor features a small base and an improved cable management design that hides cables in the monitor riser, for a clutter free desk space at your office or home office. -
Comfort is key
Tilt, swivel and adjust the height of your monitor to a maximum of 150 mm because you should be comfortable however and wherever you work. -
Easy on the eyes
Optimize eye comfort with a flicker-free screen and ComfortView, a feature that reduces harmful blue light emissions. -
The power of USB-C
Get high power delivery via USB-C, so you can keep your laptop battery full and enjoy uninterrupted productivity. This single-cable solution also saves much workspace setup time, reduces cable clutter and transmits power, data and audio - all at once. -
Multitask efficiently
Connect two PCs to the monitor and display the content at the same time with Picture-by-Picture (PbP) and Picture-in-Picture (PiP) features. Use the KVM (keyboard, video and mouse) feature to edit content from two different PCs using a single keyboard and mouse. -
Quick convenience
Plug in whatever you need and keep it in reach with the two, SuperSpeed USB 5 Gbps (USB 3.2 Gen1) quick access ports.
- Dell P3421WM - LED monitor - curved - 34"
- LED-backlit LCD monitor - 34"
- Energy Class
- Class F
- Power Consumption (On mode)
- 31.5 W
- Curved Screen
- KVM Switch, USB 3.2 Gen 1 hub, USB PD 65 Watt
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- WQHD 3440 x 1440 at 60 Hz
- Pixel Pitch
- 0.2325 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, DisplayPort, USB-C
- Height, swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 100-240 V (50/60 Hz)
- Black
- Dimensions (WxDxH) - with stand (lowest position)
- 81.57 cm x 23.74 cm x 39.11 cm
- 10.8 kg
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified EPEAT Gold
- DisplayPort 1.2, HDCP 2.3
- Bundled Services
- 3 years Advanced Exchange Basic Warranty
- Designed For
- Latitude 3320, 3420, 3520, 5320, 5320 2-in-1, 5420, 5421, 5520, 5521, 7320, 7420, 7520, 9420, 9520, 9520 2-in-1; OptiPlex 3080, 3090, 5090, 7090; Precision 3240, 3450, 3650; Vostro 13 5310, 14 5410, 15 5510, 15 7510, 5415, 5515, 7500; XPS 13 9310, 15 9510
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 34"
- Curved Screen
- Yes (3800R)
- Built-in Devices
- USB Power Delivery
- 65 Watt
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- Pixel Pitch
- 0.2325 mm
- Pixel Per Inch
- 109
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Vertical Refresh Rate
- 48 - 85 Hz
- Horizontal Refresh Rate
- 30 - 85 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- Picture by picture, Flicker Free technology, Dell Easy Arrange, Dell ComfortView, Picture-in-Picture, narrow-bezel design, 8-bit + A-FRC Colour Depth, 3-sided bezeless
- Black
- 81.57 cm x 23.74 cm x 39.11 cm - with stand (lowest position)
- 10.8 kg
- HDMI , DisplayPort 1.2 , USB-C upstream/DisplayPort Alt Mode with Power Delivery (power up to 65W) , USB 3.2 Gen 1 upstream , 2 x USB 3.2 Gen 1 downstream , 2 x USB 2.0 downstream
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 60
- Height Adjustment
- 150 mm
- VESA interface support, security lock
- Cables Included
- 1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x HDMI cable , 1 x USB-C 3.2 Gen 1 cable , 1 x USB 3.2 Gen 1 upstream cable
- Input Voltage
- 31.5 W
- Power Consumption SDR (On mode)
- 31.5 kWh/1000h
- Power Consumption (Typical)
- 31.5 Watt
- Power Consumption (Max)
- 126 Watt
- Power Consumption Stand by
- 0.3 Watt
- 0.2 Watt
- Included Software
- Dell Display Manager
- Dimensions & Weight Details
- With stand (lowest position) - width: 81.57 cm - depth: 23.74 cm - height: 39.11 cm - weight: 10.8 kg , Without stand - width: 81.57 cm - depth: 5.81 cm - height: 36.54 cm - weight: 6.7 kg
- Shipping Weight
- 14.9 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- ENERGY STAR Version
- 8.0
- Bundled Services
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Designed For
- Dell Latitude 3320, 3420, 3520, 5320, 5320 2-in-1, 5420, 5421, 5520, 5521, 7320, 7320 Detachable, 7420, 7520, 9420, 9520, 9520 2-in-1 , Dell OptiPlex 3080, 3090, 5090, 7090 , Dell Precision 3240 Compact, 3450 Small Form Factor, 3650 Tower , Dell Vostro 13 5310, 14 5410, 15 5510, 15 7510, 5415, 5515, 7500 , Dell XPS 13 9310, 13 9310 2-in-1, 15 9510
Dell SB521A Magnetic Sound bar | In Stock | £28.02 |
Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse | In Stock | £58.86 |
Dell Thunderbolt Dock WD22TB4 180W | In Stock | £188.18 |
Dell Dell Pro Wireless Mouse MS5120W Black | In Stock | £23.75 |
