Dell P3421W 34" 3440x1440 5ms HDMI DisplayPort USB-C Curved IPS LED Monitor
Quicklinx: G73TWS00 Mfr#: DELL-P3421W
Productivity that pulls you inFocus like never before on this immersive, curved monitor with a WQHD screen, improved cable management and up to 65W of power delivery.
Dell P3421W - LED monitor - curved - 34.14" - with 3-year Basic Advanced Exchange
LED-backlit LCD monitor - 34.14"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/347530
Energy Class
Class F
Power Consumption (On mode)
31.5 W
Curved Screen
USB 3.2 Gen 1 hub, USB PD 65 Watt
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
WQHD 3440 x 1440 at 60 Hz
Pixel Pitch
0.2325 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 1000:1 (dynamic)
Response Time
5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
1.07 billion colours
Colour Gamut
99% sRGB
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
81.57 cm x 23.74 cm x 39.11 cm
10.8 kg
Environmental Standards
TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
688 kg carbon emissions
DisplayPort 1.2
Bundled Services
3 years Advanced Exchange Basic Warranty
Latitude 5320, 5520; XPS 13 9310, 15 9510
Display Type
Energy Class
Class F
Diagonal Size
34.14"
Curved Screen
Yes (3800R)
Built-in Devices
USB 3.2 Gen 1 hub
USB Power Delivery
65 Watt
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.2325 mm
Pixel Per Inch
109
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
99% sRGB
Response Time
Vertical Refresh Rate
48 - 85 Hz
Horizontal Refresh Rate
30 - 85 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Flicker Free technology, Dell Easy Arrange, Dell ComfortView, 3-sided bezeless, 99% sRGB colour gamut
81.57 cm x 23.74 cm x 39.11 cm - with stand
10.8 kg
HDMI , DisplayPort 1.2 , USB-C upstream/DisplayPort Alt Mode with Power Delivery (power up to 65W) , USB 3.2 Gen 1 upstream , 2 x USB 3.2 Gen 1 downstream , 2 x USB 2.0 downstream
Mechanical
Tilt Angle
-5/+21
Swivel Angle
60
Height Adjustment
150 mm
VESA interface support, security lock
DisplayPort 1.2
Input Voltage
31.5 W
31.5 kWh/1000h
Power Consumption (Typical)
32.75 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand - width: 81.57 cm - depth: 23.74 cm - height: 39.11 cm - weight: 10.8 kg , Without stand - width: 81.57 cm - depth: 5.84 cm - height: 36.6 cm - weight: 6.7 kg
Shipping Weight
14.9 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
ENERGY STAR Version
8.0
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
119
Manufacturing (kg CO2e)
395.05
Logistics (kg CO2e)
73.8
Use (kg CO2e)
214
EOL (kg CO2e)
4.24
Total Carbon w/o Use Phase (kg CO2e)
474
PAIA Version
1.2.10, 2020
Bundled Services
10 - 90% (non-condensing)
Dell Latitude 5320, 5520 , Dell XPS 13 9310, 15 9510
