Dell P2418D 23.8" 2560x1440 8ms VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: DXB3WS00 Mfr#: DELL-P2418D
From Excel spreadsheets to colorful PowerPoint presentations, see more fine details on this crisp display. Colors are vivacious and accurate, even across a wide 178°/178° viewing angle with 99% sRGB color coverage. Get optimal connectivity for high-definition content, thanks to the convenient DisplayPort and HDMI ports.
  • Bring out every detail
  • Vibrant visuals
  • Connect without compromising
Dell P2418D - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
29 kWh
Power Consumption (On mode)
20 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.205 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (fast), 8 ms (normal)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
53.89 cm x 18 cm x 35.69 cm
Carbon Footprint
510 kg carbon emissions
TUV, RoHS, WEEE, E-Standby, CEL, EuP
Latitude 7400 2-in-1
Display Type
Energy Class
Class A
29 kWh
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.205 mm
Pixel Per Inch
123
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
99% sRGB
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
99% sRGB colour gamut
53.89 cm x 18 cm x 35.69 cm - with stand
DisplayPort , HDMI , USB 3.0 upstream , 3 x USB 3.0 downstream , USB 3.0 downstream with Battery Charging 1.2
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, VESA interface support, Dell Soundbar mounting slots, anti-theft stand lock slot
1 x DisplayPort cable , 1 x SuperSpeed USB panel
Security Slot Type
Kensington security slot
Input Voltage
20 W
Power Consumption (Typical)
20 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
Without stand - width: 53.89 cm - depth: 5.16 cm - height: 32.07 cm - weight: 3.44 kg , With stand - width: 53.89 cm - depth: 18 cm - height: 35.69 cm
Sustainability Information
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
93
Manufacturing (kg CO2e)
334
Logistics (kg CO2e)
48
Use (kg CO2e)
125
EOL (kg CO2e)
3
Total Carbon w/o Use Phase (kg CO2e)
385
PAIA Version
9/5/2018
10 - 80% (non-condensing)
Dell Latitude 7400 2-in-1
