Dell P2414H 24" 1920x1080 8ms VGA DVI DisplayPort LED Monitor
Quicklinx: 922KWS00 Mfr#: 860-BBBG
The Dell 24 Monitor – P2414H adjusts to fit your work style and provides virtually all the connectivity options you'll need over the course of the day.
Dell P2414H - LED monitor - Full HD (1080p) - 23.8" - with 3-Years Advanced Exchange Service and Premium Panel Guarantee
LED-backlit LCD monitor - 23.8"
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Voltage
56.6 cm x 18 cm x 36.9 cm
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
RoHS, CECP
Bundled with
Display Type
Diagonal Size
23.8"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP
56.6 cm x 18 cm x 36.9 cm - with stand
Bundled with
DVI-D (HDCP) , DisplayPort , VGA , USB 2.0 upstream , 3 x USB 2.0 downstream
Mechanical
Stand
1 x DisplayPort cable , 1 x USB cable , 1 x VGA cable
RoHS, CECP
Security Slot Type
Kensington security slot
Input Voltage
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
10 - 80% (non-condensing)
922K C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £17.83
922K C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £13.62
922K C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £16.94
