Dell P2223HC 21.5" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: HDLJWS00 Mfr#: DELL-P2223HC
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 5ms
Interfaces: DisplayPort, HDMI, USB-C
£173.87 ex VAT
£208.64 inc VAT
Maximize productivity on the 21.5-inch FHD monitor with a three-sided ultrathin bezel, powerful connectivity, ComfortView Plus and an eco-friendly design.
Dell P2223HC - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1039874
Energy Class
Class D
Power Consumption (On mode)
12 W
USB 3.2 Gen 1/USB-C hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24795 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 1000:1 (dynamic)
Response Time
14 ms (normal), 5 ms (fast)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
48.726 cm x 17.957 cm x 48.199 cm
4.97 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
544 kg carbon emissions
RoHS, DisplayPort 1.2, BFR-free, HDCP 1.4, PVC-free
Bundled Services
3-Years Advanced Exchange Service and Premium Panel Guarantee
Display Type
Energy Class
Class D
Diagonal Size
21.5"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24795 mm
Pixel Per Inch
102.46
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
99% sRGB
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED edgelight backlight
Mercury free, arsenic-free glass, 3-sided bezeless, Dell ComfortView Plus
48.726 cm x 17.957 cm x 48.199 cm - with stand
4.97 kg
HDMI (HDCP 1.4) , DisplayPort 1.2 (HDCP 1.4) , DisplayPort output (HDCP 1.4, MST) , USB-C 3.2 Gen 1 upstream/DisplayPort 1.2 Alt Mode with Power Delivery , 4 x USB 3.2 Gen 1 downstream
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
Cable tie
1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB-C cable - 1.8 m
Input Voltage
12 W
12 kWh/1000h
Power Consumption (Max)
118 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.2 Watt
On / Off Switch
Dimensions & Weight Details
With stand - width: 48.726 cm - depth: 17.957 cm - height: 48.199 cm - weight: 4.97 kg , Without stand - weight: 3.03 kg
Shipping Weight
6.63 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
117
Manufacturing (kg CO2e)
350.54
Logistics (kg CO2e)
58.6
Use (kg CO2e)
131
EOL (kg CO2e)
3.7
Total Carbon w/o Use Phase (kg CO2e)
413
PAIA Version
1.3.0, 2021
Bundled Services
Accessories (1)
HDLJ Dell Dual Monitor Stand - MDS19 In Stock £174.65
Other bundles (3)
HDLJ Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £33.60
HDLJ Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE In Stock £159.87
HDLJ Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £45.19
Response Time: 5ms
Interfaces: HDMI
Interfaces: USB-C
Brand: Dell
