Flexible multi-tasking
Seamlessly connect up to three devices with this premium keyboard and mouse combo. The dual mode RF 2.4 GHz and Bluetooth 5.0 connectivity lets you effortlessly switch across devices with the connection-mode key or button on your keyboard and mouse. -
Navigate with precision
Easily maneuver across monitors of varying resolutions at home or in the office. Dell Peripheral Manager (DPM) software enables you to manage your input devices and adjust to your preferred preset DPIs at 1000, 1600, 2400 or 4000. -
Customize your way
Gain instant access to your frequently used applications or functions with 12 programmable keys on your keyboard and 5 programmable mouse buttons. Power through your work with a full-sized keyboard that comes with a dedicated numeric pad, function keys, and programmed presets. Download the DPM software and easily pair your devices, adjust DPI on your mouse, check battery and connectivity status, program shortcuts and update to the latest firmware. -
Well-crafted design
The thoughtfully designed quiet keyboard is slim and stylish with a premium feel and titan gray finish. Experience all day comfort thanks to the sculpted mouse that fits perfectly in your hand. The adjustable tilt legs on your keyboard give you the flexibility to work in your ideal typing position. -
Durable and secure
The Dell Premier Multi-Device Wireless Keyboard and Mouse combo has been rigorously tested to work seamlessly with your Dell system. The keyboard offers 128-bit AES (Advanced Encryption Standard) encryption protecting your data transmission across your PCs and devices, providing you with a secure connection while typing.
- Dell Premier Multi-Device KM7321W - keyboard and mouse set - QWERTY - UK - titan grey Input Device
- Keyboard and mouse set
- Interface
- 2.4 GHz, Bluetooth 5.0
- Wireless Receiver
- USB wireless receiver
- Connectivity Technology
- Wireless
- Localization and Layout
- QWERTY UK
- Hot Keys Function
- Volume, mute
- Pointing Device
- Mouse - wireless - optical
- Buttons Qty
- 7
- Titan grey
- Bundled Services
- 3 years NBD Advance Exchange
- Interface
- Wireless Receiver
- Dimensions (WxDxH) / Weight
- Keyboard: 43.33 cm x 12.15 cm x 2.836 cm / 561 g , Mouse: 6.97 cm x 11.45 cm x 4.16 cm / 84 g
- Bundled Services
- Wireless
- Hot Keys Function
- Volume, mute
- QWERTY UK
- Keyboard Technology
- Scissors
Pointing Device
- Mouse - wireless
- Buttons Qty
- 7
- Movement Detection Technology
- Optical
- Movement Resolution
- 4000 dpi
- Batteries:
- 1
- Supported Battery Type
- AA x 1
- Titan grey
- Included Accessories
- AA battery, 2 AAA batteries
- AES-128
- Included Software
- Dell Peripheral Manager (Windows only)
- OS Required
- Apple MacOS, Android, Google Chrome OS, Microsoft Windows 7 / 8.1 / 10, Red Hat Enterprise Linux 8.0, Ubuntu 18.04
