Easily adjust your monitor to your desired angle, height, and position so you can enjoy great visuals across multiple monitors with no hassle.
A more seamless workflow
Slim borders create a smoother and less obstructed visual experience when working across multiple monitors. -
Versatility you can count on
Enjoy full adjustability to pivot, tilt, adjust the height, and swivel your monitor to your exact preference. -
More ways to stay connected
Multiple connectivity ports on the bottom and side of the monitor allow you to easily connect to various devices. -
Screen performance
View your applications, spreadsheets and more on a 19.5-inch monitor with 1600 x 900 HD clarity, 16.7 million colors, and a contrast ratio of 1000:1. -
Work comfortably
The flicker-free screen with ComfortView, a feature which helps reduce harmful blue light emissions, optimizes eye comfort. -
Auto mode and PowerNap
Color settings of your applications are now customizable and allow for presets. And with PowerNap, you can worry less about wasting energy when you're away from your computer.
- Dell P2018H - LED monitor - 20"
- LED-backlit LCD monitor - 20"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/344923
- Energy Class
- Class D
- Energy Consumption per Year
- 24 kWh
- Power Consumption (On mode)
- 9.7 W
- USB 3.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1600 x 900 at 60 Hz
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (black-to-white)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1931), 84% (CIE 1976)
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- 46.15 cm x 18 cm x 33.88 cm
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
- 428 kg carbon emissions
- CECP, CEL, TUV Rheinland Low Blue Light Certification, BFR-free, PVC-free
- 3-year warranty
- Bundled Services
- 3-Years Advanced Exchange Service and Premium Panel Guarantee
- Designed For
- Latitude 7400 2-in-1
- Display Type
- Energy Class
- Class D
- 24 kWh
- Diagonal Size
- 20"
- Viewable Size
- 19.5"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Per Inch
- 94
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Backlight Technology
- WLED
- PowerNap, stand lock, Flicker Free technology, BFR/PVC-free, Energy Gauge, Dell ComfortView
- 46.15 cm x 18 cm x 33.88 cm - with stand
- DisplayPort , HDMI , VGA , 2 x USB 2.0 downstream , USB 3.0 upstream , 2 x USB 3.0 downstream
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), VESA interface support
- Cables Included
- 1 x SuperSpeed USB cable , 1 x VGA cable , 1 x DisplayPort cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 9.7 W
- Power Consumption SDR (On mode)
- 9.7 kWh/1000h
- Power Consumption (Typical)
- 14 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- Included Software
- Drivers & Utilities
- Dimensions & Weight Details
- With stand - width: 46.15 cm - depth: 18 cm - height: 33.88 cm , Without stand - width: 46.15 cm - depth: 5.01 cm - height: 27.32 cm - weight: 2.4 kg
- Shipping Weight
- 6.13 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
- 85
- Manufacturing (kg CO2e)
- 301
- Logistics (kg CO2e)
- 36
- Use (kg CO2e)
- 89
- EOL (kg CO2e)
- 2
- Total Carbon w/o Use Phase (kg CO2e)
- 339
- PAIA Version
- 9/5/2018
- Limited warranty - 3 years
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
- Designed For
- Dell Latitude 7400 2-in-1
