Always on the go? No more worries about running out of battery power! You can power your Laptop with this 6-cell lithium-ion battery from Dell. With a capacity of up to 65 WHr, the battery lets you work seamlessly when you are on the move for business trips or vacations. This battery provides uninterrupted reliable performance you need to get the most out of your system.
- Dell Primary Battery - laptop battery - Li-Ion - 65 Wh
- Laptop battery
- Battery
- Lithium Ion 6-cell - 65 Wh
- 1-year warranty
- Designed For
- Latitude E6230, E6330, E6430S
- Laptop battery
- Technology
- 6-cell Lithium Ion
- Capacity
- 65 Wh
- Limited warranty - 1 year
- Designed For
- Dell Latitude E6230, E6330, E6430S
