Dell N4032 Switch L3 Managed 24 x 10GBase-T
Quicklinx: BTPSWS00 Mfr#: 210-ABVS
The N4000 switch series offers a power-efficient and resilient 10 Gigabit Ethernet (10GbE) switching solution with support for 40GbE uplinks for advanced Layer 3 distribution for offices and campus networks. The N4000 switch series has high-performance capabilities and wire-speed performance utilizing a non-blocking architecture to easily handle unexpected traffic loads. The N4000 series includes dual internal hot-swappable 80PLUS-certified power supplies for high availability and power efficiency. The switches offer simple management and scalability via flexible user port stacking at 10 Gbps or 40 Gbps. The high-availability stacking architecture allows management of up to 12 switches from a single IP address.
  • Modernize campus network architectures
    Modernize campus network architectures with a power-efficient and resilient 10/40GbE switching solution for environments requiring high throughput and availability at the aggregation or core. For greater interoperability in multivendor networks, all N-series switches offer the latest open-standard protocols and include technology to interface with Cisco protocol RPVST+ and devices using CDP. Achieve high availability and full bandwidth utilization with Multi-chassis Link Aggregation (MLAG). All N-series switches support MLAG to create active/active loop-free redundancy without spanning tree. Server rooms can deliver reliable server and storage connectivity with features to help save time and avoid configuration errors. These high density 48-port 10GbE switches are ready for converged fabric requirements for SAN and LAN networks with loss-less operation for iSCSI environments with Data Center Bridging (DCB). The N4000 series is also fully tested and validated to work with Dell EqualLogic PS-series storage arrays.
  • Leverage familiar tools and practices
    All N-series switches include Dell Networking OS 6 designed for easier deployment, greater interoperability and a lower learning curve for network administrators. One common command line interface (CLI) and GUI using a well-known command language gets skilled network administrators productive quickly. This allows network administrators to maintain consistent configurations by running one OS release across all N-Series products. With USB auto-configuration, network administrators can rapidly deploy mirrored configurations to numerous devices by simply inserting a USB key.
  • Deploy with confidence at any scale
    N4000 series switches help create performance assurance with a data rate up to 1.28 Tbps (full duplex) and a forwarding rate up to 952 Mpps. Scale easily with 10/40 Gbps user port stacking supporting distances up to 100 meters. Switch stacks of up to 672 10GbE ports can be managed from a single screen using the highly-available stacking architecture for high-density aggregation with seamless redundant availability.
Dell Networking N4032 - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
24 x 10GBase-T
Performance
Switching fabric bandwidth: 640 Gbps , Forwarding performance: 476 Mpps
MAC addresses: 131072 , IPv4 routes (static): 1024 , IPv6 routes (static): 1024 , IPv4 routes (dynamic): 8160 , IPv6 routes (dynamic): 4096 , Maximum member ports per LAG: 8 , Maximum dynamic ports per switch stack: 144 , LAG groups: 128 , Priority queues per port: 8 , OSPF routes: 8160 , RIP routes: 512 , ECMP next hops per route: 4 , ECMP groups: 1024 , VLAN routing interfaces: 128 , VLANs supported: 4094 , Multicast entries (IPv4): 512 , Multicast entries (IPv6): 256 , ARP entries: 6144 , NDP entries: 400 , ACL: 100 , Maximum rules per ACL: 1023 , Max ACL rules system-wide: 3072 , Maximum ACL rules per interface (IPv4) egress rules: 1023 , Maximum ACL rules per interface (IPv4) ingress rules: 2047 , Maximum ACL rules per interface (IPv6) egress rules: 512 , Maximum ACL rules per interface (IPv6) ingress rules: 1021 , Maximum VLAN interfaces with ACLs applied: 24
MAC Address Table Size
131072 entries
Routing Protocol
OSPF, RIP-1, RIP-2, IGMPv2, IGMP, VRRP, OSPFv2, PIM-SM, PIM-DM, IGMPv3, OSPFv3, MLDv2, MLD
Remote Management Protocol
SNMP 2, SNMP, RMON, HTTP, SSH
Layer 3 switching, Layer 2 switching, MDI/MDI-X switch, auto-negotiation, port mirroring, stackable, Broadcast Storm Control, IP address filtering, Access Control List (ACL) support, Quality of Service (QoS), Dynamic ARP Inspection (DAI), LLDP support, Remote Switch Port Analyzer (RSPAN), Management Information Base (MIB), dual firmware images, redundant fans, MAC and IP-based ACLs support, Time-controlled ACLs support, Protocol-based VLANs support
IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.3ac, IEEE 802.1s, IEEE 802.1v, ANSI/TIA-1057, IEEE 802.1ag, IEEE 802.1ab (LLDP), IEEE 802.3az, IEEE 802.1Qbb, IEEE 802.1Qaz
Power Redundancy
43.383 cm x 45.999 cm x 43.43 cm
9.83 kg
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
24 x 10GBase-T
Performance
131072 entries
Routing Protocol
Encryption Algorithm
AES, SSL, TLS 1.0
Authentication Method
RADIUS, TACACS+, LDAP
RAM
2 GB
Flash Memory
256 MB
24 x 10GBase-T RJ-45 , 1 x Gigabit LAN RJ-45 management , 1 x serial (RS-232) RJ-45 management , 1 x USB Type A management
Expansion Slots
1 (total) / 1 (free) x Expansion Slot
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Provided
460 Watt
176 Watt
FCC Class A certified, cUL, GS, RoHS, WEEE, REACH, ICES Class A, EAC, CCC Class A
43.383 cm
45.999 cm
43.43 cm
9.83 kg
Limited warranty - parts - lifetime
50 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
BTPS C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
BTPS C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.93
BTPS C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.49
