N-series is a family of energy-efficient and cost-effective 1GbE and 10GbE switches designed for modernizing and scaling network infrastructure. The Dell Networking N3000 series offers high-availability GbE switches for Layer 3 access or aggregation, providing easy-to-manage solutions.
The Dell Networking N3000 series has Power-over-Ethernet Plus (PoE+) without an external power supply. This allows you to attach devices with high power requirements (up to 30.8 watts) without running a separate power cable. PoE+ is particularly useful in older buildings where installing power to multiple, widespread locations can be prohibitively expensive.
Modernize your network
N-series is a family of energy-efficient and cost-effective 1GbE and 10GbE switches designed for modernizing and scaling network infrastructure. The Dell Networking N3000 series offers high-availability GbE switches for Layer 3 access or aggregation, providing easy-to-manage solutions. -
Deliver clean power to network devices with PoE+ support
The Dell Networking N3000 series has Power-over-Ethernet Plus (PoE+) without an external power supply. This allows you to attach devices with high power requirements (up to 30.8 watts) without running a separate power cable. PoE+ is particularly useful in older buildings where installing power to multiple, widespread locations can be prohibitively expensive. -
Designed for efficiency
Built to help keep operating costs down, the N3000 series can operate at temperatures up to 113°F (45°C) to help reduce cooling costs. -
Advanced feature set to simplify management
The Dell Networking N3000 series is designed for easy deployment, outstanding interoperability and a low learning curve for network administrators. A single OS release allows you to maintain consistent configurations across all N-series products with a comprehensive feature set. -
Deploy with confidence at any scale
With high throughput and capacity to handle unexpected workloads, the N3000 series switches are ideal Layer 3 solutions for fast growing GbE networks that require high-density aggregation with seamless redundancy and availability.
- Dell Networking N3024P - switch - 24 ports - Managed - rack-mountable
- Switch - 24 ports - L3 - Managed - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000 + 2 x 10 Gigabit SFP+ + 2 x combo Gigabit SFP
- Power Over Ethernet (PoE)
- PoE+
- Performance
- Switching fabric bandwidth: 212 Gbps , Forwarding performance: 158 Mpps , Stacking bandwidth: 84 Gbps
- Capacity
- MAC addresses: 16384 , IPv4 routes (static): 1024 , IPv6 routes (static): 1024 , IPv4 routes (dynamic): 8160 , IPv6 routes (dynamic): 4096 , Maximum member ports per LAG: 8 , Maximum dynamic ports per switch stack: 144 , LAG groups: 128 , OSPF routes: 8160 , RIP routes: 512 , ECMP next hops per route: 4 , ECMP groups: 64 , VLAN routing interfaces: 128 , VLANs supported: 4094 , Multicast entries (IPv4): 512 , Multicast entries (IPv6): 256 , ARP entries: 6144 , NDP entries: 400 , ACL: 100 , Maximum rules per ACL: 1023 , Max ACL rules system-wide: 4096 , Maximum ACL rules per interface (IPv4) egress rules: 1024 , Maximum ACL rules per interface (IPv4) ingress rules: 3072 , Maximum ACL rules per interface (IPv6) egress rules: 512 , Maximum ACL rules per interface (IPv6) ingress rules: 1021 , Maximum VLAN interfaces with ACLs applied: 24
- MAC Address Table Size
- 16K entries
- Routing Protocol
- OSPF, RIP-1, RIP-2, IGMPv2, IGMP, VRRP, PIM-SM, PIM-DM, IGMPv3, OSPFv3, MLDv2, MLD
- Remote Management Protocol
- SNMP 2, SNMP, RMON, HTTP, SSH
- Layer 3 switching, Layer 2 switching, MDI/MDI-X switch, auto-negotiation, port mirroring, stackable, Broadcast Storm Control, Multiple Spanning Tree Protocol (MSTP) support, Per-VLAN Rapid Spanning Tree (PVRST), Energy Efficient Ethernet, Dynamic VLAN Support (GVRP), dual firmware images, Network Access Control (NAC), tagged VLAN, redundant fans, Protocol-based VLANs support
- IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.3ac, IEEE 802.1s, IEEE 802.1v, IEEE 802.1ag, IEEE 802.1ab (LLDP), IEEE 802.3az
- Power Redundancy
- Optional
- 43.4 cm x 40.7 cm x 4.35 cm
- 6.6 kg
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- Performance
- Capacity
- 16K entries
- Routing Protocol
- Encryption Algorithm
- MD5, AES, SSL, TLS
- Authentication Method
- Secure Shell (SSH), RADIUS, TACACS+
- RAM
- 1 GB
- Flash Memory
- 256 MB
- 24 x Gigabit LAN RJ-45 , 2 x 10Gbit LAN SFP+ , 2 x Gigabit LAN , 1 x serial (RS-232) RJ-45 management , 1 x USB Type A , 2 x network stack device
- Expansion Slots
- 1 (total) / 1 (free) x Expansion Slot
- Power Device
- Internal power supply - hot-plug
- Installed Qty
- 1
- Max Supported Qty
- 2
- Power Redundancy
- Optional
- Power Provided
- 715 Watt
- FCC Class A certified, cUL, GS, RoHS, WEEE, REACH, ICES Class A, EAC, CCC Class A
- 43.4 cm
- 40.7 cm
- 4.35 cm
- 6.6 kg
- Limited warranty - lifetime
- 0 °C
- 50 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 65 °C
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.71 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £14.87 |
