Dell N1124P 24-port Managed Gigabit Ethernet Switch
Quicklinx: F6PJWS00 Mfr#: 210-AJIT
The N1100 switch series offers a power-efficient Gigabit Ethernet (GbE) network-access switching solution with integrated uplinks. With high-performance capabilities and wire-speed performance, utilizing a non-blocking architecture to easily handle unexpected traffic loads, the switches offer simple management and scalability via a full-duplex high-availability stacking architecture, that allows management of a few switches from a single IP address. Features, such as Energy-Efficient Ethernet and short cable detection, provide energy efficiency to help decrease power and cooling costs.
  • Modernize campus network architectures
    Modernize campus network architectures with a power-efficient and resilient switching solution with PoE/PoE+ ports. PoE power budgets deliver clean power to network devices, such as wireless access points (APs), Voice-over-IP (VoIP) handsets, video conferencing systems and security cameras.
  • Leverage familiar tools and practices
    One common command line interface (CLI) and graphic user interface (GUI), using a well-known command language, gets skilled network administrators productive quickly. The N1100 switch series also supports the Open Network Install Environment (ONIE), enabling installation of alternate network operating systems.
  • Deploy with confidence at any scale
    N1100 series switches help create performance assurance with a high data and forwarding rate. Scale easily by stacking with 10GbE ports. Switch stacks of a few ports can be managed from a single screen, using the highly available stacking architecture for high-density aggregation with seamless redundant availability.
Dell EMC Networking N1124P-ON - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed - stackable
Enclosure Type
Front to back airflow rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (12 PoE+) + 4 x Gigabit SFP / 10 Gigabit SFP+
Power Over Ethernet (PoE)
PoE+
PoE Budget
190 W
Performance
Switching capacity (full duplex): 128 Gbps , Forwarding rate: 96 Mpps
MAC addresses: 16000 , LAG groups: 64 , Virtual interfaces (VLANs): 512 , ARP entries: 2048 , NDP entries: 400 , ACL rules: 4000
MAC Address Table Size
16000 entries
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, TFTP
Flow control, auto-negotiation, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), DiffServ support, IPv6 support, Rapid Spanning Tree Protocol (RSTP) support, Per-VLAN Spanning Tree Plus (PVST+), IPv4 support, LLDP support, Link Aggregation Control Protocol (LACP), Management Information Base (MIB), Dynamic VLAN Support (GVRP), redundant fans
IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.3ac, IEEE 802.1s, IEEE 802.1v, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
43.18 cm x 25.4 cm x 4.445 cm
3.78 kg
Enclosure Type
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
190 W
Performance
16000 entries
Routing Protocol
Encryption Algorithm
AES, SSL, TLS 1.0
Authentication Method
RADIUS, TACACS+, Secure Shell v.2 (SSH2)
RAM
1 GB
Flash Memory
1 GB
12 x Gigabit LAN RJ-45 PoE+ , 12 x Gigabit LAN RJ-45 , 4 x 1/10Gbit LAN SFP+ , 1 x USB Type A
Internal power supply
Installed Qty
1
Power Provided
250 Watt
249.6 Watt
Rack Mounting Kit
Included
FCC Class A certified, UL, cUL, GS, EMC, RoHS, WEEE, REACH, ICES Class A, NRTL, VCCI Class A, EAC, CCC Class A, FDA 21CFR1040.10, FDA 21CFR1040.11, NAL, ACMA RCM
43.18 cm
25.4 cm
4.445 cm
3.78 kg
Limited warranty - parts - lifetime
45 °C
0 - 95%
Min Storage Temperature
-40 °C
Max Storage Temperature
65 °C
Humidity Range Storage
0 - 85%
