Dell N1108P 8-port Managed Gigabit Ethernet Switch
Quicklinx: F6PFWS00 Mfr#: 210-AJIX
Built to help keep operating costs down, the N1100 series can help reduce cooling costs. Improve your overall efficiency with great features.
Dell Networking N1108P-ON - switch - 8 ports - Managed - rack-mountable
Switch - 8 ports - Managed - stackable
Enclosure Type
Front to back airflow rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (4 PoE+) + 2 x Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
75 W
Performance
Switching fabric bandwidth: 24 Gbps , Forwarding performance: 18 Mpps
MAC addresses: 16000 , Aggregated links (dynamic): 144 , LAG groups: 64 , Queues per port: 8 , VLANs supported: 512 , ARP entries: 2048 , NDP entries: 400 , Max ACL rules system-wide: 4000 , ACL: 100 , Maximum ACL rules per interface (IPv4) ingress rules: 1023 , Maximum ACL rules per interface (IPv4) egress rules: 1023 , Maximum ACL rules per interface (IPv6) ingress rules: 1021 , Maximum ACL rules per interface (IPv6) egress rules: 253
MAC Address Table Size
16000 entries
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 2, SNMP, RMON, Telnet, HTTP, TFTP, SSH-2
Layer 2 switching, MDI/MDI-X switch, auto-negotiation, port mirroring, IP address filtering, Access Control List (ACL) support, Quality of Service (QoS), LLDP support, Remote Switch Port Analyzer (RSPAN), Management Information Base (MIB), dual firmware images, redundant fans, MAC and IP-based ACLs support, Time-controlled ACLs support
IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.3ac, IEEE 802.1s, IEEE 802.1v, ANSI/TIA-1057, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az, IEEE 802.3ax
21.6 cm x 25.4 cm x 4.45 cm
2.01 kg
Enclosure Type
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
75 W
Performance
16000 entries
Routing Protocol
Encryption Algorithm
AES, SSL, TLS 1.0
Authentication Method
RADIUS, TACACS+, LDAP
RAM
1 GB
Flash Memory
1 GB
4 x Gigabit LAN RJ-45 , 4 x Gigabit LAN RJ-45 PoE+ , 2 x Gigabit LAN SFP , 2 x Gigabit LAN RJ-45 management , 1 x USB Type A , 1 x
Internal power supply
FCC Class A certified, UL, cUL, GS, RoHS, WEEE, REACH, ICES Class A, NRTL, VCCI Class A, EAC, CCC Class A, FDA 21CFR1040.10, ACMA, FDA 21CFR1040.11, RCM Class A
21.6 cm
25.4 cm
4.45 cm
2.01 kg
Limited warranty - parts - lifetime
45 °C
95%
Min Storage Temperature
-40 °C
Max Storage Temperature
65 °C
Humidity Range Storage
85%
